Pre 84 Trucks 1st gen pickups
help with identifiying a hose
Old Jan 1, 2007 | 11:35 AM
Foxtrot's Avatar
I am doing a head gasket on my 82' 22r
There is a plate that screws into the bottom of the intake manifold. and on this plate there is a port I cant figure out what hose plugs into this port.
Old Jan 1, 2007 | 11:55 AM
EWAYota's Avatar
i picture would help, but if its like the 22RE..(pulling from memory)...it should be a coolant pipe that bolts on under the intake then runs from that port, behind the head (where it bolts on) and connects to a hose on the firewall above the header.
Old Jan 1, 2007 | 05:48 PM
4Hummer's Avatar
This is an RE but pretty similar
Old Jan 1, 2007 | 06:17 PM
DeathCougar's Avatar
should be a coolant hose
22re's have totally different intakes anyways, so you cant really compare those
The pipes you two are talking about is the heater piping, which is metal and bolts to the back of the timing cover. One on each side (water pump then pumps water through these hardlines to the soft hoses near the firewall etc etc)
Old Jan 1, 2007 | 07:46 PM
Foxtrot's Avatar
hmm let me upload a picture ... I know about the hose that is connected to the thermosatic valve that is attaches to the head. I am talking about the port that is on the plate that is attached to the bottom of the intake manifold
the port is the one in the center of the image
Old Jan 1, 2007 | 11:52 PM
yea, thats a water port. I've nevr driven anything carbbed before, but the corosion is a dead give away (well, plus I've been working on Toyota's for over 5 years)
Old Jan 2, 2007 | 05:42 AM
Foxtrot's Avatar
ok granted it's a water port where does the hose go on the other end? I asked one of my buddies and he thinks it goes to a port that comes off of the timing cover I am thinking why is there water going into my intake
Old Jan 2, 2007 | 07:25 PM
1eye's Avatar
Thats the one the rubber hose hooks onto which in turn hooks onto the pipe running to the back of the timing chain cover.
Old Jan 3, 2007 | 06:41 AM
Foxtrot's Avatar
Ok I think you are right ....sweet I guess now I have to put it together ...thanks all
Old Jan 3, 2007 | 09:27 AM
deserttoy84's Avatar
they wouldnt have water temp sensors on the intake if water didnt run through.
kawazx636
Oct 6, 2021 03:03 PM
ladybugRC
458
Aug 21, 2020 10:41 AM
wberry85
May 17, 2016 05:45 PM
kcaudill
Oct 10, 2015 02:39 PM
taraf
Sep 25, 2015 02:57 PM
