Pre 84 Trucks 1st gen pickups
heavy rust on end of SA (knuckle)
Old Aug 25, 2007 | 04:01 PM
HAVOC's Avatar
I was cleaning my axle housings today. The part where the felt and rubber seal is heavily rusted. I stopped in at Autozone and bought some "Klean-Strip rust remover" to see what it would do. I'm not a fan of rust removers/convertors. I'd guess I try it while waiting for an answer from someone on this site.
Has anyone sanded the ends of the axle without damaging them? What about sandblasting, too severe? Any thoughts on cleaning these things up?
Thanks...
The only thing not rusted on this truck is the title.
Old Aug 25, 2007 | 04:18 PM
slacker's Avatar
not a big deal , the wipers are just to keep the axle balls clean .. from dirt and crap contaminating the knuckle grease .
use some emery cloth and just clean em up a bit .
Old Aug 25, 2007 | 04:20 PM
waskillywabbit's Avatar
Yep, just use some very fine grit sandpaper to clean it up.
Old Aug 26, 2007 | 08:13 AM
HAVOC's Avatar
this is a pic of the rust:
Old Aug 26, 2007 | 03:44 PM
slacker's Avatar
wow .. that is fairly serious ..
Personally , I would replace . sand blasting , or grinding smooth again would not be enough .. the replacement seals/felts are NOT avaliable oversized . I fear if you tried to repair , water would still be able to contamanate the knuckle grease .
Old Aug 26, 2007 | 04:10 PM
HAVOC's Avatar
Yep, it's got deep pitting all over the knuckle ball (both sides). If it was just surface rust I'd be okay. The pic is a little out of focus so it's worse than it looks. At least the parts that I took out are good.
Well for now I'm putting the axles and body on the backburner while I try to locate a frame.
Old Aug 26, 2007 | 04:49 PM
4Crawler's Avatar
Have heard of folks filling in pitting like that with body filler or epoxy and then sanding it smooth.
Old Aug 26, 2007 | 05:11 PM
HuskyRunner's Avatar
Definately do what you can to save it - they can be pricey to replace. A friend of mine was quoted $1000 at the dealership for a knuckle for his '83!
Old Aug 26, 2007 | 08:00 PM
toy283's Avatar
BTDT. I sanded mine down a bit then took a wire brush real good to the pitted/scored areas to clean out the rust. Then I spead on a thin layer of J-B Weld and worked it into the pits. A few days later when it was fully cured I sanded it down to bare metal, leaving the epoxy to fill the pits and scores. Re-apply and re-sand if necessary. Several years later, it is still working fine.
Old Aug 27, 2007 | 01:09 AM
HAVOC's Avatar
I may know someone who has a '85 axle for sale, (need to give them a call). If I get it I wont have to worry about the upper gusset, correct?
Old Aug 27, 2007 | 04:05 PM
HAVOC's Avatar
axle is going bye-bye with the remainder of scrap metal
young buck
18
Aug 27, 2018 02:40 PM
Sep 4, 2015 09:27 AM
the1998sr5
Jul 16, 2015 06:20 AM
Nickdigg
Jul 7, 2015 06:04 AM
MTLroadierunner
Jul 6, 2015 12:17 PM
