Pre 84 Trucks 1st gen pickups
Power Steering Conversion?
Old Feb 2, 2007 | 10:37 AM
Yota Tony's Avatar
My 82 doesn't have power steering.
Will parts from a newer truck work?
Anyone sell a kit to convert it?
Thanks!
Old Feb 2, 2007 | 05:07 PM
4Crawler's Avatar
Grab the p/s parts from another similar engined truck; pump, pulley, reservoir, lines, fittings, etc. Should bolt right up, at least they do on a 22R or 22RE. Not sure if that is the engine you have or not.
On the steering box, two options.
1. Get a box from anything up to 1985 and keep the stock push-pull steering. Box should bolt right up.
2. Convert to crossover steering and then get a box from 1986-1995 and use that instead. Requires some drilling, cutting and welding to install crossover steering.
Old Feb 2, 2007 | 08:15 PM
myyota's Avatar
I just had a 5" lift put on my 85 toyota truck and also added cross over steering with a late model IFS steering box, my truck didn`t come with power steering so i got a power steering pump and hoses off of an 89 two wheel drive truck, i will have to drill a couple of holes to mount the reservoir and the cooler line but other than that everything bolts on.
Old Feb 5, 2007 | 11:10 AM
4XTOYOTAX4's Avatar
you need to make sure you have a threaded boss on the cylinder head, to mount the idler pulley. Most 20r engines dont. Everything else is no prob.
Old Feb 5, 2007 | 02:56 PM
Yota Tony's Avatar
Truck has a 22R.
Old Feb 8, 2007 | 05:07 PM
Yota Tony's Avatar
Found all the stuff locally. Getting it next Tuesday.
Zpd426
Jan 2, 2016 01:15 PM
Up&Down
Aug 11, 2015 10:04 AM
toyoterferdayz
Diesel Swaps
Jul 27, 2015 05:25 PM
gmonnie123
Jul 26, 2015 02:44 PM
yoterr
Jul 24, 2015 04:29 AM
