PDA
View Full Version : Pre 84 Trucks
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 [19] 20 21 22 23 24 25
  1. Pictures of battery tray on 1981 4x4 ?
  2. 1982 22R Carburetor Emissions Throttle Positioner troubles
  3. opinions on companies?
  4. Timing Issues
  5. 81 2WD pickup
  6. 4 Runner bucket seats for a 80 toy
  7. Pics of first gen interiors???
  8. swapin 3rds
  9. Quality sound in a 1983 (audio upgrade)
  10. did a little bit of wheeling today
  11. 20r get'n hot need help !!!!!
  12. trouble shifting my 79 / need 5sp
  13. Fuel backsiphons ?
  14. Broken motor mounts??
  15. Toyota 3" lift gone wrong :(
  16. Oil pan plug leaks
  17. What do the letters on the 20r/22r valvecover cap stand for?
  18. truck bed help please
  19. flatbed
  20. need info and detail gm alternator
  21. Input shaft bearing and seal
  22. 80 P/U build ideas? cheap ones
  23. Rear Brake Upgrade
  24. Toppers for our Toyotas
  25. Help with Birfield repair (noob)
  26. 81 yota small project
  27. '80 4cyl. 20R water pump bolt torque specs? I got the 6cyl. specs thou...
  28. 81 or 83?
  29. 81 or 83?
  30. I'm in a fusible link nightmare! HELP
  31. Toyota Swap Meet & Club's
  32. brushguards for '83 pickups
  33. An 82 or 83
  34. The little beast project
  35. creepin outta 3rd
  36. aluminum radiator
  37. 1982-3 SR5 cluster for sale on Marlin
  38. 1983 springover axle pros & cons
  39. Dual mikuni sidedrafts, are they worth it?
  40. How do you remove the front clip on a late 70's yota truck?
  41. Who would have pre-1st parts?
  42. 81 wont start
  43. Alternator does not charge?
  44. speculation on starter diagnosis
  45. Aftremarket Intake manifolds
  46. smokin deals on seats
  47. terrible banging noise
  48. looking to get a header
  49. Bending float tabs
  50. Steering help
  51. lift help
  52. parting out 82 pickup
  53. put in some platinum ngk's today, question.
  54. 83 toyota axle strength
  55. 80 2wd yota with 3k original miles(wrecked bad)
  56. need LSPV help
  57. 82 4x4 overcharging!
  58. 22r vacuum
  59. vacuum hose diagram??
  60. Couple 82' 4x4 Questions...
  61. 79 20R won't start. Narrowed down to carb issue. prob.
  62. Removing oil pan '82 2wd
  63. Tranny is toasted !!
  64. got a question on a bolt size
  65. no dash gauges please help!!
  66. Tie rod loose
  67. Audiovox Cruise Control
  68. 1977 Hilux with a 5th wheel camper HELP!!!!
  69. 75-78 vs. 79-85 drivetrain
  70. new timing chain
  71. My '83, first truck & first Toyota
  72. Best rebuild kit
  73. spline question???/
  74. Temp Sensor
  75. Rad support
  76. 81 pre-runner HELP!!!!
  77. '86 Carb onto an '82 22r
  78. problems on the highway
  79. 2nd gen gas tank into 1st gen
  80. Will a 2nd gen gas tank fit?
  81. what years of 22rs will fit in my 1982 toyota mojave
  82. 4-link
  83. Problems after installing new cam
  84. timing chain help
  85. honest opinions needed! frankenstein 83
  86. 85 into 80?
  87. manual to power steering
  88. waggy springs?
  89. 1981 Chinook - Opening a can of worms...
  90. Half doors
  91. New Twin Sticks
  92. New seats for my '80 PU
  93. major steering problems on 81
  94. Picked up a nice little deal today
  95. good deal?
  96. the cursed '83
  97. 1980 20R 5 speed intermitantly runs badly
  98. 20R carb to 22R intake
  99. Stalling issues
  100. Trouble shifting into first sometimes:shift boot removal
  101. 82 door panels
  102. 22R stumbling idle, dies when coasting to a stop
  103. Steering issues. (Truck picks the path)
  104. Trail gear shackles?
  105. thin/odd colour oil after rebuild
  106. headlight relay wrong part?
  107. runs rough on warm restart?
  108. Big Brake upgrade
  109. 22r exhaust manifold gasket
  110. oil leakage in brake drum
  111. bucking and loss of power
  112. Bench seating
  113. springs
  114. Help me choose suspension for a new build
  115. double transfer cases
  116. checking gear ratio
  117. 22r no power....
  118. shackles in the front?
  119. Rust Repair by a first timer :D (warning: big pics)
  120. 81 2WD pick up over heating issue.
  121. Need help Wiring ignitor coil
  122. wag springs up front?
  123. power steering fluid ?
  124. Should I reuse gaskets? RTV? or both?
  125. 22R oil pump question
  126. 82 22R Carb Question
  127. Want to Lift my 82
  128. 80's fiberglass crewcab Yota
  129. Trouble shooting starting trouble
  130. truck wont start, it's my fault
  131. where do you get rearend parts?
  132. 1983 Pickup Fusible Link?
  133. Attention yotaboy 82
  134. Transfer case issue
  135. Bad rattle when letting off throttle at 55mph
  136. 81 4x4 tranny rebuild questions
  137. 22r with lots of blow by.
  138. Removal of Air Injection System? 79 2wd 20r
  139. front bumper help???
  140. i need valve help
  141. 83 toyota first time wheeling it.
  142. New members pics!
  143. ???stock fuel pump or electric fuel pump???
  144. drivability issue
  145. oil punmp question and fuel question
  146. Head Gasket gone?
  147. ticking sound from dash, speedo cable?
  148. Oh my nice straight body wasnt so straight !!!
  149. Tires VS Gears
  150. putting an e-locker in the front of my 83?
  151. front spring mounting
  152. 81 4X4 rear driveshaft 6' bed
  153. No power....at all
  154. Repairing a crack in the frame
  155. 82 toyota problems
  156. Solid Axle rebuild..w/pictures :)
  157. carb gasket
  158. typical old truck problems
  159. new guy, and i got some pics
  160. 4.70 or dual t-case?
  161. Rebuilding engine advice needed
  162. 83' Timing chain?
  163. Help with my high idle
  164. radiator problems
  165. Power brake trouble?
  166. Napa gold fuel filter.
  167. Shock hoops?
  168. Wiring problems
  169. Nicer 83 yota bed here in Nor Cali
  170. Edelbrock intake? good/bad
  171. HELP! My 4runner Is Stuck Revving High :(
  172. cheap way to get a wee bit more power out of these little unstoppable engines?
  173. i need help finding parts for my truck
  174. stuck throttle ?
  175. Changing Clutch Fluid, Capacity
  176. Clogging fuel filter?
  177. new sound in front driver wheel
  178. How much play is allowable on tranny input shaft?
  179. in big trouble! warped a friends LCE head!!!!
  180. 1983 Pickup Fuse Panel Info Needed
  181. 82 4x4 is this a good deal
  182. My 82 4x4
  183. Engine Problem
  184. broken timing chaing guides
  185. Propane rocks my face off!!!!
  186. Tuning weber 32/36 DGEV
  187. Dipstick help
  188. 83 toyota trailblazer?
  189. shocks
  190. propane problem
  191. 81 doors on an 83?
  192. 83 toyota
  193. L52 Shift Lever removal
  194. Major problems with my head lights
  195. 1st gen pickup guys with the 22R..
  196. four way flasher?
  197. Chance to buy a 1st gen. However...
  198. 79 Door/fender stickers
  199. 1982 pickup no run, lots of smut
  200. Turbo+ propane+20-22r who can help?
  201. Fuel Filter issue fixed?
  202. 84 - 81 parts
  203. Clutch bleeding
  204. 22r oil pressure problem
  205. top speed ?
  206. 4WD Emblems Pricing
  207. rears from an 89 in my 82?
  208. Alternator/Regulator Problems!?!?
  209. Air intake ideas?
  210. A call to arms
  211. Custom center console build
  212. High steer question ????
  213. Battery overcharging (1979 4WD)
  214. part time 20R
  215. 89-95 Bed install on a 79-83 shortbed ?
  216. Need some feedback on lifts
  217. 4" rough country springs- steering problem
  218. new cam, now what?
  219. Weber 38 rebuild ???
  220. Vin info
  221. Driveshaft for a W56 swaped 1st gen
  222. Mud truck aka The poor boy junkyard build
  223. Terrible gas mileage!
  224. second life
  225. 1st Gen Bolt Pattern Question
  226. 91 toyota on 81 4x4 frame ? ? ?
  227. Anyone live in Nor cali area ?
  228. 18r stalling issue
  229. 22R in place of 20R, Help
  230. 22r question
  231. Picked up 22R last night Pics!!
  232. i need help. 84 4x4 pickup. alternator problem
  233. 1980 truck fuel gauge problems
  234. oil pump problems
  235. Seat Covers for 1982 2WD Deluxe
  236. 1st gen 2wd bed & 4wd bed comparisons
  237. oil pump leak
  238. tire questions
  239. Timing chain question 82 22r
  240. Carb mounting gasket?
  241. R452 Tranny
  242. I need some tachometer help please
  243. Loose stick shift, what do I need?
  244. More bad news after compression test
  245. Headgasket? Cracked Block?
  246. Figurin Lift
  247. home made welder
  248. gearing issues(newbie)
  249. SR5 cluster
  250. Engine shuttering really bad.
