Pre 84 Trucks 1st gen pickups
power steering fluid ?
Old May 14, 2009 | 03:23 PM
ajoebob's Avatar
i seen on anuther site someone said toyotas use ATF (automatic transmission fluid) for power steering fluid and you souldnt use power steering fluid but only atf. is this true of all years just newer ones or what?
thanks
Old May 14, 2009 | 03:24 PM
Ardent's Avatar
Yup that's true. The cap should say to use ATF.
Old May 14, 2009 | 03:28 PM
DeathCougar's Avatar
Use Dexron II/III ATF fluid for the PS system. If you have the owners manual, it will recommend using that.
Old May 14, 2009 | 04:03 PM
slacker's Avatar
X3 ...... check your manual .
Old May 14, 2009 | 04:27 PM
ajoebob's Avatar
well then i know what i have to do tomarow
i didnt know that and always toped it off with power steering fluid. it looks like its all power steering fluid so i'll drain it all off and try to flush it out good.
Old May 16, 2009 | 07:47 PM
ajoebob's Avatar
i got it all changed out. it wasnt bad to do at all. it did look bad anyways so it needed to be changed. thanks for the help
Zpd426
Jan 2, 2016 01:15 PM
Up&Down
Aug 11, 2015 10:04 AM
gmonnie123
Jul 26, 2015 02:44 PM
yoterr
Jul 24, 2015 04:29 AM
whereAreMyPants
Jul 22, 2015 03:32 AM
