Pre 84 Trucks 1st gen pickups
'86 Carb onto an '82 22r
Old Jun 5, 2009 | 10:02 PM
iridebikes's Avatar
Howdy,
My buddy has a carb that's in good condition from an '86 22r and I'm wondering if it will work on my '82.
My carb is currently in need of some major work so I'm thinking this might be an easier solution than rebuilding the old one if it will transfer.
Any help would be appreciated!
Thanks.
Old Jun 6, 2009 | 05:57 AM
scooper's Avatar
That 86 should have fuel injection. Sounds like someone has already been swapping stuff around, check it out and see what exactly it is, I'm 99% positive it will fit your vehichle tho.
Old Jun 6, 2009 | 07:09 AM
iridebikes's Avatar
Yeah, that's what I was thinking, but I don't know if maybe it was an option to have carb or EFI? I can't seem to find any differences between the carb he has and the one that is in my pickup so I'm thinking it SHOULD work.
Thanks man!
Old Jun 10, 2009 | 07:42 AM
farmall's Avatar
82 p/u : I have an after market carb but no diagram of vaccum lines. the old carb lines were cut in place. no way to tell which way they go. Does any body have a diagram??? I bought this carb for my 87 p/u and it is identical to the old one on the 82 so they are interchangable
Old Jun 10, 2009 | 07:45 AM
83's Avatar
83
I had an '87 with a carb. Apparently on 2wd models you could even get carbs into the early 90's.
Old Jun 10, 2009 | 08:48 AM
algranger's Avatar
Yeah carbs went well past 86, the 86 carb should swap right over on to your 82
Old Jun 13, 2009 | 09:57 AM
dezrik's Avatar
I just swapped in a 87 toyota 4WD Pickup into my first gen, And it had a factory carb on it. They limited carb models after 87. I bought this pickup (87) and thought it was EFI till i came to collect it.
buckz6319
Aug 5, 2017 03:50 AM
Iceman4193
Oct 16, 2015 10:50 AM
Thamuel_
Domestic Swaps
Oct 3, 2015 11:15 AM
Toys4parts
Sep 26, 2015 01:56 PM
taraf
Sep 25, 2015 02:57 PM
