Pre 84 Trucks 1st gen pickups
Aftremarket Intake manifolds
Old Jun 27, 2009 | 04:22 PM
skooterbumm's Avatar
is it worth the money? does anyone run one? good or bad ones?
Old Jun 30, 2009 | 09:47 AM
maybe i didnt comunicate this well. I have a weber carb with the 2 peice adapter that always leaks. Ive tried everything still develops a leak after a few months. I was looking at offy manifolds made for the webber to bolt directly onto. I also saw a "dual plane" version (seems restrictive to me) does anyone have any experience with this?
Old May 12, 2012 | 06:12 PM
rbmoomba's Avatar
I wish someone wiuld have answered.... Im facing a similar problem and you can always tell its leaking again by the decreased idle. Instead of the usual gasoline safe rubber sheet i used a gasoline safe gasket maker. Wish me luck. We shall see in the morning
Old May 12, 2012 | 08:39 PM
JonnyBoy's Avatar
Cheaper than an aftermarket intake manifold is a better adapter for the carb. LC Engineering has a 2 piece adapter that makes a good seal because it's machined instead of cast. There's also a 1 piece adapter by Trans-Dapt that people have had good luck with. I had problems with the kit pieces sealing, too, but haven't had any since putting on the LC Engineering adapter a little over a year ago.
LittleUgly
15
Jan 2, 2020 01:30 PM
puddlepirate
Jul 30, 2016 06:29 PM
wberry85
May 17, 2016 05:45 PM
Thamuel_
Domestic Swaps
Oct 3, 2015 11:15 AM
the_supernerd
Oct 1, 2015 09:20 PM
