Pre 84 Trucks 1st gen pickups
I'm in a fusible link nightmare! HELP
Old Jul 5, 2009 | 05:22 AM
NYota's Avatar
Question I'm in a fusible link nightmare! HELP
I was retarded and didn't disconnect the battery when I changed the driver side motor mount. What could go wrong, right! Ended up shorting out the mount against the alt. It didn't smoke and was only against the mount for 4-6 sec. Traced the short back to the IC regulator. I found a fried node. After replacing the IC reg I still don't have my radio, taillights, brake lights and dash lights. I've also checked the voltage on both sides of the 'green' connectors at the battery with my voltage meter. I got conductivity thought each green adptor. Someone told me these are fuses, but it seems to be just a plug? I gave them a good tug anyway and they seem fine. I looked under the dash and found two relays, switched them up and there was no difference. Could they both be blown? Checked the wiring from the fuse box to the taillights and it all seems to be good.
live4soccer7
May 11, 2016 06:52 PM
SpookyMulder
Nov 4, 2015 11:56 AM
Davebarbier
Nov 3, 2015 03:28 PM
Thamuel_
Domestic Swaps
Oct 3, 2015 11:15 AM
myotherrideisayoshi
Sep 29, 2015 05:41 AM
