Pre 84 Trucks 1st gen pickups
terrible banging noise
Old Jun 25, 2009 | 09:47 AM
jeepman's Avatar
so ever since i got my yota a week ago when i hit about 15+ miles per hour it starts making a banging noise but only when i hit the gas,the second i let off the gas it goes away and i cannot figure it out it sounds as if something is spinning and banging against something else
i have already checked tranny mount and front driveshaft but it sounds as if its coming from the rear end
and advice is great thanks
Old Jun 25, 2009 | 10:26 AM
BigBluePile's Avatar
Sounds like the rear end. Pull the drain plug on the housing and see what "falls" out.
Old Jun 25, 2009 | 10:32 AM
Elton's Avatar
u joints ?
Old Jun 25, 2009 | 11:37 AM
slisdexia's Avatar
is your driveshaft attached at both ends?
Old Jun 25, 2009 | 07:21 PM
desertcamper67's Avatar
Jack up the rear end (both tires) run it in 2wd and listen.
Old Jun 26, 2009 | 12:27 PM
jeepman's Avatar
checked u joint too but i will try jacking it up asap to check it
zytra
Jan 24, 2019 03:16 PM
primordialbeast117
Dec 19, 2015 12:23 PM
Obmi
Oct 4, 2015 11:30 AM
Brodetski
Sep 30, 2015 11:50 PM
