Pre 84 Trucks 1st gen pickups
1983 Pickup Fuse Panel Info Needed
Old Apr 11, 2009 | 05:15 PM
YotaMan2390's Avatar
Hey. I have a 1983 Pickup 4WD. I don't have the cover to my fuse box, and I need to know which fuse is which. I searched ALL over everywhere to find a fuse diagram, but even my Toyota book only shows diagrams for 70-78 models.
If anyone can tell me what each fuse is, or has a picture of a diagram, or even a picture of the cover (assuming the cover says on it) that would be great.
Thanks.
Old Apr 11, 2009 | 05:50 PM
dropzone's Avatar
Fossilized
here is a scan from the wiring diagram for my '81, might get you pointed in the right direction:
Old Apr 11, 2009 | 09:02 PM
Thanks but not quite. My friend has a '79 and I used to have an '80. Apparently they use similar fuse set-ups.
'82 and '83 stopped using the bar fuse. =/
Old Apr 11, 2009 | 09:59 PM
kjvforme's Avatar
Here you go ...
Old May 13, 2018 | 11:34 AM
Toyorider84's Avatar
I have the same problem with my 83 pickup.
Need the fuse box diagram for my 83 pickup. Could anybody help me out?
Old May 14, 2018 | 06:12 AM
toy_tek's Avatar
you need the fuse layout or the fuse box wiring diagram?
Old May 14, 2018 | 06:21 AM
Fuse panel diagram
Yes I need the layout of the fuse box.
Old May 14, 2018 | 07:12 AM
Lons81's Avatar
Here is the one out of 81 4X4. hope it helps. Dang it, can't get pic any smaller
Old May 14, 2018 | 07:17 AM
toy_tek's Avatar
from my 83
Old May 14, 2018 | 12:03 PM
Originally Posted by toy_tek
from my 83
much thanks
Old Sep 29, 2021 | 06:14 AM
keller_adam's Avatar
Do you know where to find one of those heater fuses? Can’t find one anywhere
Old Sep 29, 2021 | 10:36 AM
2ToyGuy's Avatar
It's actually a circuit breaker. CBXXX...
Check the dealership. I believe they carry them. BTW: did you try resetting it? Might be all it takes...
Pat☺
alfonz33
9
Nov 16, 2015 09:21 AM
BigArt70
Jun 30, 2015 09:51 PM
LSUMatt1514
60
Oct 10, 2003 12:30 PM
HALMAN
Jun 14, 2002 09:02 PM
