1983 Pickup Fuse Panel Info Needed
Hey. I have a 1983 Pickup 4WD. I don't have the cover to my fuse box, and I need to know which fuse is which. I searched ALL over everywhere to find a fuse diagram, but even my Toyota book only shows diagrams for 70-78 models.
If anyone can tell me what each fuse is, or has a picture of a diagram, or even a picture of the cover (assuming the cover says on it) that would be great. Thanks. |
here is a scan from the wiring diagram for my '81, might get you pointed in the right direction:
http://i119.photobucket.com/albums/o...wiring/024.jpg |
Thanks but not quite. My friend has a '79 and I used to have an '80. Apparently they use similar fuse set-ups.
'82 and '83 stopped using the bar fuse. =/ |
I have the same problem with my 83 pickup.
Need the fuse box diagram for my 83 pickup. Could anybody help me out? |
Originally Posted by Toyorider84
(Post 52398376)
Fuse panel diagram
Yes I need the layout of the fuse box. |
1 Attachment(s)
(Post 52398432)
Yes I need the layout of the fuse box. https://cimg5.ibsrv.net/gimg/www.yot...af4bc4140.jpeg |
Originally Posted by toy_tek
(Post 52398436)
Do you know where to find one of those heater fuses? Can’t find one anywhere
It's actually a circuit breaker. CBXXX...
Check the dealership. I believe they carry them. BTW: did you try resetting it? Might be all it takes... Pat☺ |
