PDA
View Full Version : Pre 84 Trucks
Pages : 1 2 3 4 [5] 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25
  1. comfy replacement seats 1982 4WD
  2. Tie rod - Can't find replacement?
  3. Fast idle question
  4. LT Brake Light and Rt Turn Sig issues
  5. Reproduction Parts
  6. Need help with gauges not lighting up
  7. 1982 22R Engine sputters and idles rough in gear, drives fine
  8. Weber to Asian conversion
  9. Speedo lights to LEDs?
  10. Parts for sale thread?
  11. 1988 toyota 4x4 pick up bed
  12. LSPV Bleeder Valve
  13. Need help guys
  14. No braking power with Trail gear rear disc brake kit
  15. Wear on inside of axle housing okay?
  16. Identify Skid Plate
  17. 74 and/or 78 wolverine craigslist find?
  18. What does a 79-83 cost?
  19. Toyota pickup 1982
  20. 82 Toyota OME lift before and after
  21. fj60 backspacers
  22. Charging Issues
  23. It's Coming Together
  24. Slight Play in L52 Transmission
  25. Smoking on compression
  26. Looking for 1983 tailgate
  27. 1st gen project
  28. Front Windshield 1987 4Runner
  29. suggestions before turning over my 83 20R?
  30. Winch Installation
  31. New here- Just purchased this '82:
  32. New to forum! Purchased a 77' Chinook
  33. Build suggestions for a 22r
  34. New Door Glass
  35. Parking brake cable
  36. sloppy ujoint/loose yoke.
  37. 1st gen toyota waggy 4404 question
  38. 22r fuel supply low pressure to weber.
  39. Horn and Wipers
  40. How do y'all tie down your rigs?
  41. Changing Instrument Panel
  42. Bumper Brackets to fit 89-95 bumper on '82
  43. Typical Alternator Charging Issues
  44. Newb Lift Questions: 1980 4x4 Long Bed
  45. How do I replace HEADLIGHTS?
  46. Swapping a w56
  47. 22r carb on a 20r
  48. Issues to watch for when looking for a 1st gen
  49. Mirror Swap
  50. brake rod adjustment
  51. Better stereo
  52. Strong vibration and wobble at high(er) speed
  53. Heart Transplant
  54. Damaged Valves or not?
  55. Weber 36/32 Leak
  56. Pre '84 ARB Bumper
  57. Has anyone installed AIR CONDITION into their truck that has never had AC before?
  58. Cat / Muffler recommendations
  59. How to install kill switch on 1982 Toyota pickup with mechanical fuel pump?
  60. overheating on highway
  61. Cracked Head?
  62. W56 Swap
  63. 22R Running rich, need help to correct it
  64. 83 SW thermo or vac problem...
  65. 4runner exhaust
  66. Everything is new...still water in oil
  67. Radiator for 2WD diesel
  68. 1983 pickup exhaust
  69. 1983 4wd Won't Start
  70. Rebuilding My Teenage Years
  71. Charge system fusible links
  72. 1980 project
  73. my Trekker burnt , battery fire
  74. Help; engine bay fire, now it won't idleLA.ea
  75. Vcs
  76. Vacuum line assistance
  77. Manual choke wire routing
  78. 78 hilux motor flush
  79. Stripped cam cap hole
  80. Anyone converted their manual windows to electric windows? Got any suggestions?
  81. 1982 Vibration from 45 to 55 mph in 4th gear only
  82. Are these factory?
  83. '81 22r No Spark
  84. 1981 toyota pickup sr5
  85. How to replace a muffler without the hooks?
  86. No power to fuel pump on 20R. Can I bypass the auto-shut off?
  87. Using 22R cylinder head bolts on 20R
  88. 19 volts at the alternator??
  89. 1982 SR5 4X4 pickup: Brake Load Proportioning valve?
  90. 2" Suspension lift vers Anti Torque Bar
  91. Fuse & Brake Question on my 78
  92. introduction/couple of questions
  93. 82 Diesel fuel pump replacement?
  94. Floor Pans 1971 Hilux
  95. Trail Gear Full Hydraulic Steering Kit. Has anyone installed this kit?
  96. 2nd gen (86) bed on a 1st gen (82) pickup
  97. Will an L43 bolt up to a 2TC?
  98. I know I can't keep em all
  99. alternator woes
  100. AISAN CARB ISSUES: Should I fix, rebuild, or replace w/ new Weber carb???
  101. 81 22r how do u set timing when it won't start
  102. 22r Rhythmic Clacking
  103. 1982 Beige/Black interior colors
  104. Idle adjustment 1982 22r
  105. Clutch peddle 3/4 is dead.
  106. I need two rubber gaskets for the exterior door handles of 83 truck. SUGGESTIONS??
  107. Need Help Solving my Distributor Install Problem
  108. Header identification help
  109. 2" body lift kit, vrsus drive shafts
  110. Texas to Colorado Trip Towing my First Gen
  111. rear glass seal
  112. 80 20r ac belt adjustment
  113. Can I put a Holley 600 on a 22R??
  114. Alright guise. Moving forward on synthesized gas
  115. 1983 22r with megasquirt and no timing advance
  116. Tranny swap
  117. 20r hard starting warm
  118. 1983 22r with megasquirt and no timing advance
  119. what can I get at with the tranny down??
  120. Head gasket recomendation
  121. to rebuild or not to rebuild? (22-r)
  122. Inner Axel Wont Come Out
  123. early 22r cylinder head source?
  124. 22R rebuild
  125. How can I remove dried paint and rust stains from black rubber side window gaskets?
  126. How to remove side vent windows from 83 pickup truck?
  127. Carb tuning
  128. 22r to 22re swap
  129. Using leveling blocks for front of truck?
  130. Crank bolt
  131. Cylinder walls
  132. HELP! Dual Case Nightmare!!
  133. Starting issues
  134. 4 speed manual to auto tanny swap qeustion
  135. Another 4.3 swap advice needed
  136. Need advice for big swap
  137. Starter for 76 Hilux, 20r
  138. Stuck 1983 outer door handles
  139. Just ordered Ruff Stuff 63" spring swap kit and have a question
  140. How does my rear shackle angle look?
  141. 20r Desmog Help
  142. Anyone ever purchase one of these rebuilt carbs?
  143. Head gasket help for 82 22 r
  144. 2nd gen dash/interior in 1st gen.
  145. Easy fix?
  146. I've reached the end of the internet
  147. 81 Build with pics
  148. Altitude questions...
  149. Rockauto
  150. HELP: Need instructions for re-installing windshield on 82 pickup truck
  151. quick charge light question (Bulb test/check)
  152. Fuel gauge sender revisited
  153. 83 pickup crossover steering question
  154. Manifold vacuum at idle
  155. Clutch chatter after spring lift install
  156. rear window rebuild
  157. 1982 Toyota SR% stripes painted on hood
  158. 22r carbed starts, runs, stalls
  159. 81 rough idle when warm
  160. odd ball question
  161. 1982 Pickup alternator problems
  162. 80 w/ 22r carb/ignition help
  163. Transfer case mount question
  164. 82 4x4 Pickup Steering Wheel Options
  165. ISO '83 4x4 Rear Suspension SPRING SEAT
  166. Weak Spark / No Spark
  167. 1983 sr5 engine swap to 2jz twin turbo
  168. 1978 20r. High Idle, Dieseling, timing?
  169. Parking Brake Delete
  170. Suspected Bad Pinion Bearing....
  171. torque rod mod with 3" lift?
  172. 4 speed transmission swap
  173. Working on a combination switch connector
  174. Custom clutch setup for engine swap.
  175. 79-83 Camper shell
  176. restored 82 Toyota 4x4
  177. 1983 Window glass seal leak?
  178. Something different....awd conversion
  179. Wide wheels and tires.
  180. Supercharged 82 oil explosion, lost compression.
  181. Ties? Size?
  182. Head gasket replacement success, but engine running really choppy (1980, 20r)
  183. Anyone know these 82 radio outs?
  184. 1980 toyota 4x4 value?
  185. Converting back to full 22r??
  186. Small cap distributor? Or something?
  187. 78 2wd bed on 83 4wd
  188. igniter with carburetor and points?
  189. 1983 pickup wiring gremlins
  190. 1983 Toyota Sunrader jolt while accelerati
  191. Help with '83 Yota
  192. 22R Stock or Performance Source??? 1983
  193. Vacuum Piping issue!
  194. weber carb 83 Toyota SR5 pu
  195. '83 4x4 and w56
  196. Are rear leaf springs the same for RWD and 4WD?
  197. Pulling to the left in 4WD when off throttle
  198. Carb Sight glass
  199. Yotalockers.com - Elockers for Early Pick Ups
  200. 1983 4x4 front axle rebuild HELP!
  201. what is this "spring damper" in my distributor?
  202. Rebuilding a trans
  203. 20R/Carb/4-Speed Swap
  204. 1980 Toyota question PLEASE READ
  205. weird engine noise!! what is it??
  206. GM 3 wire Alternator in an 81
  207. 1st Toyota, Newest Fleet Member!
  208. 83 with a 20r?
  209. Hello, new here but have been a member since 2010
  210. L43 backup switch removal
  211. Box Rocket 1980 Hilux
  212. Bearing Clearance Questions
  213. Need New Engine for 1983 Toyota P/U SR5
  214. Reverse lights backup switch issue
  215. Transfer Case eBrake
  216. How to find what I need?
  217. can you ID this trans?
  218. Question about adjusting front ride height for 1980 2WD (w/ torsion bars)
  219. '83 5-Speed 4x4 Transmission Problem
  220. what is this clunk
  221. Transmission transfer housing gasket
  222. Diamond plate door panels
  223. Oil in coolant but not head gasket???
  224. What are these?!
  225. Clutch and transmission Questions
  226. Stuck carb insulator
  227. Woops.
  228. 1980 20r Tuning Difficulty
  229. OEM 8 track player question??
  230. What stock steering wheel will fit
  231. power steering pump question
  232. '82 4-Speed Trans - do these gears look okay??
  233. 1980 brake upgrade
  234. Carb choice on an 82 22r
  235. Transfercase issue, need some help
  236. Trying to find parts
  237. SMOGGING 20r '79! VTV'S!
  238. smogging toyota '79
  239. Overcharging issue. Your thoughts??
  240. Yotayard! Stay away!
  241. Help with headlights
  242. Round headlight conversion question??
  243. Weber carb swap performance
  244. Introducing my self.
  245. The most exciting break down for me ever
  246. Vacuum diagrams needed PLEASE...
  247. Smog question for toyota '79 truck valve assy air switch
  248. Dash lights/back up lights stay on :(
  249. 1980 rear window gasket
  250. '83 transmission problems
