Pre 84 Trucks 1st gen pickups
Stripped cam cap hole
Old Jun 12, 2017 | 05:16 PM
farrier's Avatar
Can I run a tap down in there?
A little longer bolt in that hole? I could catch a few threads.
Some kind of insert?
New head?
It started well, but never grabbed, like it was already stripped.
Thanks
Old Jun 12, 2017 | 05:28 PM
gsp4life's Avatar
Is this head a new casting or old that you put a new cam in?
If it's new, I'd look into the process for a free replacement under warranty. If old helicoil should be fine. Those bolts don't get much torque, iirc it's around 12-14 ft/lbs.
Old Jun 12, 2017 | 05:33 PM
farrier's Avatar
Yes old that I'm changing cam.
Thanks gsp4life
Old Jun 13, 2017 | 07:45 AM
wyoming9's Avatar
Red face
The thread insert of your choice .
Quite a few on the market now.
Just watch the chips and drill your hole straight
Old Jun 13, 2017 | 07:51 PM
farrier's Avatar
Thanks Wyoming, I'll go check and see what I can find tomorrow.
Old Jun 14, 2017 | 05:00 PM
farrier's Avatar
How do I remove this bushing so I can tap this for a insert?
Attached Thumbnails Stripped cam cap hole-100_4328.jpg   Stripped cam cap hole-100_4329.jpg
Old Jun 14, 2017 | 05:06 PM
gsp4life's Avatar
Those bushings are just press fit in there and probably not that tight. When my Engnbldr head showed up, I was cleaning off the protective oil film with brake clean and one fell out when I had it upside-down.
Someone may have a better idea, but I'd start with a penetrating oil, put a short piece of steel rod inside and clamp the outside with locking pliers then gently twist back and forth. The purpose of the short piece of rod is to prevent the bushing from deforming, so make sure it's a real close fit.
Old Jun 14, 2017 | 05:11 PM
farrier's Avatar
Thank you sir. I'll go give it a try!
Old Jun 14, 2017 | 05:14 PM
gsp4life's Avatar
Getting ahead of where we're at, but just thought of it on seeing the new cam.
You might already know all this but before firing it up again smear assembly lube around the cam lobes and rocker pads. Use a break-in oil and follow whatever break-in procedure revving the cam shaft manufacturer recommends or that nice new cam will go flat quick.
Old Jun 14, 2017 | 05:41 PM
farrier's Avatar
Yes I've got the break in lube.
Talked to Todd at Engnbldr and he told me the break in steps.
No luck on the bushing. Started to burr it up a little, so I quit.
I was afraid I wouldn't get the cap on right, but it's ok.
Old Jun 14, 2017 | 05:44 PM
gsp4life's Avatar
Hmm, bummer. Hopefully someone with more machinist-skills than me can chime in.
Old Jun 14, 2017 | 05:52 PM
farrier's Avatar
I guess I can destroy it getting it out and just get a new one, but I hate to mess up anything else in the process.
Could I just drill and tap on through it, or would that defeat the purpose of the bushing?
Old Jun 14, 2017 | 06:04 PM
gsp4life's Avatar
The coil repair insert will probably be larger than the inner diameter of the bushing. If not then sure, drill and tap right through it. It needs to be there in some form otherwise the cam cap could move slightly and bind against the cam while tightening it down.
Old Jun 14, 2017 | 06:07 PM
farrier's Avatar
That's correct. Insert is larger then bushing.
Old Jun 17, 2017 | 07:53 PM
farrier's Avatar
Update
Well I got that cam cap bushing out.
I used a 1/8 pipe thread tap. It fit perfect. A couple turns and it walked right out.
Bought the helicoil kit, but the tap wouldn't allow it to go down deep enough.
So I ground it so it was more of a bottoming tap, if that makes sense.
Now the insert will go down past the shoulder in the hole.
Cleaned all the bits and little pieces in the hole.
Reinstalled bushing, cap, and torqued down all caps to 14ft/lbs in a couple of steps.
