View Full Version : Pre 84 Trucks
- Need some info on factory radios and what years are interchangeable
- Need a PIC of ALT Plug-Anyone with a 1978 PLEASE!
- does anyone know where i can get a 82 pickup CHROME grill?
- 1980 pickup won't start
- '83 drive shaft length
- 1981 Toyota pickup Mud Flap Bolt size
- 22r condition pictures , what do you guys think ?
- Anybody know how to get this off?
- 1978 Toyota Chinook AC install questions
- Help!! 82 Toyota pickup Sr5 22r 4 cyl starting issues, dies when clutch released
- 82 22R Bogs under load
- More adventures with my 78 Dually
- clutch and throwout bearing questions
- Anyone sell the earlier black and white 22R valve cover stickers??
- 82 Alt/Voltage Regulator Confusion
- Can a worn gas cap effect fuel pressure
- Finally doing the clutch
- Fuel pressure regulator won't go about 1.7 psi
- Pitman Arm Availability
- My Lil green monster
- 86 alternator
- 1983 running for 500 - good deal?
- 1981 Pickup 4x4 Deluxe 350k miles - Value?
- Smoking after Desmog and installing Weber/Intake/headers
- Trying to remove emissions equipment, engine keeps dying.
- Vacuum Leaks: replace hoses or desmog it?
- Worn out carb?
- Worn out carb?
- Diesel question
- Replacement Floor Pans
- Front Bumper retrofit question
- 22r coolant in oil.
- Custom grilles? Who has them?
- Oil Question
- Strange behavior after fuel leak repair
- Difference from the helux and the 83 pickup?
- Does a 78 Qualify as a first gen? :D
- Electric cooling fan for 83
- 1972 to 1978 Pickup ALTERNATOR CONNECTOR REPAIR PARTS
- Tranny help !! :(
- Where to find an '82 bed liner?
- 63" GM leaf spring question
- 1978 Toyota Pickup 20R Won't Stay Running - Detailed
- 1982 door part question
- Need help with my 80 pickup
- 79-85 stock steelies fit ifs rear axle?
- "81 suddenly not charging
- Looking for a 1982 22r head
- First gen dash swap question.
- 81 Pickup hard to get in first gear
- Anyone with a 4 inch lift...
- 1979 Toyota Tool Set (Contents)
- OEM Buckets?
- 82 pickup lift
- 82 Pickup and towing?
- 80 20r 4 speed transmission questions
- Is there any place to buy a real weber carburator
- 82/83 Blower Fan Speed Switch - how attached to dash?
- Point me in the right direction.
- Will a intake breach allow water into oil?
- Patch panel for truck bed
- Flooding out after sitting for 30 mins
- 350 small block swaped hilux
- grinding going into reverse
- 81 Pickup problem
- oil in the coolant but not vice versa: head gasket or other passageway?
- Another no start thread, 1980 20r
- 83 Better mpg questions?
- L50 trans and 33" tires
- 83 pickup fuel gage question
- 81 toyota battery terminals with fuseable links
- Fuel Smell from Exhaust?
- differant gear ratios front and rear
- Just picked up an '82
- Wobbly steering just off center
- How to get tach to work with DUI distributor
- 22R Knocking
- Weber 38 jetting
- Performance springs and weights for distributor
- "Early Model Wiring Diagram" Photos Inside
- 1979 20r trouble starting
- Looking for a bench seat for my 80 pickup
- Before, during, and after carpet install
- Seat Help on 1983 Toyota Pickup SR5 4X4
- 1983 LWB 4x4
- any demand for single handle tailgate hardware?
- *Need Advice* on '81 22r Issue
- 1980 Toyota pickup 2jz swap (San Jose)
- 1982 Toyota p/u 4x4 starting/fuel issue
- What Transmission?
- 79 Toyota RV
- suspend set
- Looking for parts! HELP! 1st Gen Truck Stuff
- 1981 Toyota wiper linkage
- 20r/22r Hybrid Cam?
- Complete lift kit
- Cam and distributor drive
- Oil pump gears match marks?
- Replace Ignition with Toggle & Push-button Start
- Tie Rod End question
- 3SGTE Swap into an '82?
- 1983 toyota 4x4 pu lift and possible fuel problems
- Baseline Tuning Weber 32/36
- I need 1981 wiring diagram for the cluster please
- This Aussie man is either crazy or a genius. Or both. Verifiable?
- My 1980 Toyota Hilux
- factory jets 32/36 dgev
- 22r hybrid motor
- Looking for infos about this truck
- 1983 Toytoa Pickup SR5 Fender Flares
- Front output shaft seal, same as rear?
- Vinyl floor
- Oil/Volt question
- fast decision: ’01 Tundra Access Cab or 82' Pickup 4x4 Extended Bed?
- advice on 82 22R
- How much does your truck weigh?
- No Compression 22r Rebuild
- Anyone have original mud flaps? I Need patterns.
- Rims question
- Not another "will it fit" question!
- Did Toyota ever offer caps as an option for a 1983 Toyota 4x4 LWB?
- L43 woes
- De-Smogging electrical question
- FUEL LINES at the fuel pump
- Noise in 22r Engine. Stumped
- dash cluster question ?
- Question for the masses
- Name that part!
- Cracked intake manifold
- Bleeding Clutch?
- Rescued 79 4x4 short bed
- Inconsistent running 20r
- Telling the Difference Betwixt Beds
- Wheel Question
- Summit Racing A/F Gauge
- Is this really necessary?
- 1981 Toyota Pickup Fender Light Replacement
- Weber 32/36 issue, LOOK AT THESE PICS
- 1982 22r BREATHER on valve cover necessary?
- 81 Seats
- Difference in 4 and 6 cylinder 3rds for a locker?
- Newbie here- with a wrecked 1980 seeking advice
- Çhoke breaker vacuum lines go where? '77 HiLux 20R
- Engine and Transmission mounts. What are you using?
- Timing chain and other stuff input
- 1982 Toyota 4WD SR5 Pickup up for bid at Barrett-Jackson today!
- 83 4x4 loses low beams entirely, has hi beams
- Please help!? grinding that wont go away!
- 81 22r acceleration problem
- Which Direction Do I Turn Air/Fuel Mixture Screw?
- 4wd indicator light
- Beginner
- Retrofitting newer OEM steering wheel
- Paint color help
- Need a new line for the slave clutch cylinder
- Weber 32/36 bowl draining?
- Distance?
- no power to ignition switch or dash
- Intro
- 82 Trekker - Intermittent brake clunking
- Help wiring GM alternator in 75 Hilux
- rough country install
- Any difference Between 4x4 Pitman and 2 Wheel?
- Reading voltage but won't start!!
- alternator not charging
- 4WD fenders and Bed on 2WD
- 1982 22R; Crank/No Start - Found a "torn" wire - can you identify?
- 1980 4x4 Pickup Zero electricity
- 22R ticking noise
- Bells and Lights
- Questions on Winch Strength
- Bed rust
- From 1981 rpm cluster to 1983 rpm cluster
- 1980 20r misfiring
- Choke Voltage
- Idaho Smog
- 81 4x4 Headlight Relay
- 1981 Toyota Pickup Fusible Links and Battery Cable
- 81 huntsman no rear lights
- 1982 4x4 stutters going into 2nd and 3rd gear
- Anyone Know of a good wiper system replacement
- 1983 Pickup strange wiring short
- Rebuilt engine using a quart of oil every 100 miles HELP!!!
- HD transfer case mount with Buick v6 swap?
- Is my transmission screwed? (video)
- How long will 22r dbl row timing chain last?
- Horrible whistling sound (with video)
- Weber Carb Woes
- Offy intake and throttle linkage wont work
- Darn rusty frames.
- no power
- looking at buying a high milage truck - advice needed
- 40$ mystery 5 speed transmission, help identify!
- 1983 Toyota Pickup Fuel Door swap to one w/ lock??
- '82 heater water valve?
- Wheel size, HELP!
- 1980 Toyota Pickup 5SPD 2WD Trans
- Shifter Removal help
- Looking for Soft Top for 1st Gen Truck Bed
- Cold start steering sound
- '83 Hilux 2.2 Power Issues
- front oil leak and overdrive?
- 83 22r questions
- Differential Question
- options for fitting newer transmission
- Battery size?
- Post pics of turbo propane set ups with info
- looking for stereo blank
- 1st gen with intermittent wiper switch- retrofit?
- Headlight issue
- De-coding vintage '81 paint code, trim, etc
- Lifting my 83 some questions
- valves seem noisy aftyer adjustment on 22r
- Help! No start then No Power
- newbie with PNO '83 pickup
- Debating on what to do with my 83's front suspension swap
- Need help with '81, weber, and ca emissions
- '79 sr5 trans leak
- Trailgear trunnion bearing question
- 32/36 Weber power valve
- 1980 L-43 shifter help
- My 1975 Hilux
- Brake upgrade question
- idle drop when throttle is touched
- 1977 Toyota Pickup (previously a walkthrough camper)
- Intermittent brake issue...
- Post your 20R & 22R Engine Setups (Specs for internals, fuel delivery, exhaust, etc)
- 1980 20r Engine Temp Gauge problem
- 1980 longbed defrost problem
- 22RE Coolant Recovery Tank
- Trouble at 4,000
- 1982 SR5 Longbed w/ Moonroof?
- Need rear tube bumper ideas! 1981 longbed
- 20r powered allis-chalmers
- Power steering reservoir mounting
- IFS Steering Box in 1st Gen
- Seatbelt Locks
- 20 r stalling out
- Question, '78 20r, starts up but dies unless I continually pump gas pedal
- Adding Air Conditioning to pre '84 ?
- 82 Pickup Not Going Into Gear
- Boy look at this 81 beauty!
- turbo on an 83?
- 82 with a bent frame
- Gas tank suggestions...?
- Rebuilding steering u-joints
- clutch not completely disengaging by a hair
- Alternator swap, keeping it all Toyota.
- Windshield gasket
- 1983 toyota 4wd
