Pre 84 Trucks 1st gen pickups
Looking for a 1982 22r head
Old Jun 8, 2016 | 02:41 PM
jpshayes's Avatar
Anybody use these guys? - http://www.yotashop.com/1982-toyota-...XPgaAkHS8P8HAQ
These are hard to find.
Old Jun 28, 2016 | 05:57 PM
goofybud16's Avatar
Engnbldr looks to have heads as well, although they are around the same cost fully assembled.
Old Jun 28, 2016 | 06:26 PM
jpshayes's Avatar
not for an 82. They pointed me toward a few machine shops that might and they all did not have any.
Old Aug 31, 2016 | 05:35 PM
1980 Pinellas's Avatar
Can't you throw any 22r head on it? 79-83? I hope so cause mine is 82
Old Aug 31, 2016 | 05:42 PM
jpshayes's Avatar
I was under the impression that an 80-84 head is compatible. I still have not found one....
Old Aug 31, 2016 | 07:13 PM
I was looking at these, but if you look at the website it doesn't include one for a 82. I've been planning on a long read and research one these engines, but the one I have now if running and I have so many other things that need to be done , brakes , running light , windshield leak , rust , radio , dash lights , Ac , defrost vents, dash pad , small leaks on axles. The more I think about it, I need to abduct a half dozen mechanics.
http://www.lceperformance.com/Street...-p/1021021.htm
oh and a exhaust leak , I'm going to be get their headers , from what I read I should enjoy just the sound of the truck enough to make it a good purchase
Old Sep 1, 2016 | 07:40 AM
13Swords's Avatar
5 Year Member
How about?:
http://www.rockauto.com/en/catalog/t...nder+head,5304
Old Sep 6, 2016 | 02:50 AM
msane99's Avatar
you would need one built pre mid year 1984 I believe. Deck height changed after that, so the ones mass produced now will not fit 1st generation 22r's. a 20R head will work also but the intake has round ports instead of square ones. also make sure it is drilled for power steering brackets and has the opening for mechanical fuel pump if that's how you are setup. I think the fuel pump opening would only be an issue on a 20r head. that first one on the rockauto search 13swords posted looks right. their return policy is usually pretty lax too.
cars-guy
66
Jan 26, 2019 08:38 PM
RV8guy
21
Oct 2, 2017 07:04 AM
Hallam Cook
Jun 2, 2016 12:00 PM
tomboarderns
May 15, 2016 10:13 AM
11_b
Mar 29, 2016 06:41 PM
