Pre 84 Trucks 1st gen pickups
81 4x4 Headlight Relay
Old Dec 14, 2015 | 10:59 PM
astutens's Avatar
So I have removed the headlight relay from my 81 4x4 parts truck I am wiring it into my farm truck (80 Chev) I have never wired a 3 pin relay before and wanted to confirm that the signal wire should be switched to ground rather than back to its self as with a 4 pin. Also since the Toyota relay is mounted with the auxiliary light relay. I was thinking of wiring it so that high beams run through the headlight relay and the low beams run through the auxiliary relay but I am not sure how many watts the auxiliary can handle.
Matt89toyota
Jun 27, 2023 08:00 AM
Reluctanse
Nov 28, 2015 06:15 PM
9322rerunner
Oct 8, 2015 12:49 PM
1985 4Runner
Oct 5, 2015 06:20 PM
