PDA
View Full Version : Pre 84 Trucks
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 [17] 18 19 20 21 22 23 24 25
  1. Tranny, T-Case and Axle leaks!!!
  2. 81' 22r 4x4 cold start prob.
  3. Anyone replaced lower rubber boot? Need ideas!
  4. Truck Graphics-Type and Color
  5. Head light issues, light issues
  6. A/C Help Please (I have searched and still need help)
  7. 4x4 high problems
  8. 1980 shortbox 4x4 22ret?
  9. tranny swap
  10. Will a Swamper 31 9.50 x 15 fit on a stock 83 rim??
  11. 3rd gen rear leaf spings
  12. Hood Issues
  13. toyota dually 3rd's??
  14. High Idle issue
  15. Explain the carb float please
  16. timing spec
  17. New to forum, with new truck and questions
  18. grilles...
  19. 1982 Pickup stalling problem
  20. gear size in an 81' 4wd p/u?
  21. Brake up grade for 79 pickup-finding parts for 79-80
  22. 82 22r carb issues
  23. Ignition cutoff switch
  24. 81 yota 4x4 Engine probs got everyone Stumped!
  25. where do you check tansmission fluid level on 81 pick up
  26. my 81 yota is back fireing what could it be?
  27. I my tranny shot??
  28. 81 Pick-up bench seat-
  29. passenger side locking hub
  30. exhaust system for 81 pickup (input please)
  31. 83 suspension
  32. So i boosted my 83 wrong, made some sparks, now won't start
  33. alternator killer
  34. new motor... new clutch?
  35. 1981 22R Fuel Pump
  36. what is this called?
  37. New chromoly birf install question
  38. Webber Carb questions
  39. Piece broke off block
  40. Weber Carb Install Questions.
  41. setting up gear pattern
  42. swapping 22r carb onto 20r confusion
  43. what the heck is this: Roll Bar on '83
  44. Distributor/Vacuum Advance Question
  45. New To Toyota..
  46. 1st to 2nd gen grille swap
  47. Spedo Cable gear
  48. 1980 toyota hazards work but no blinkers?
  49. Flasher relay, hood? Another cab?
  50. Need Help with throwout bearing
  51. Installing IFS steering box and high steer on 81 trekker
  52. Wrist pin replacement
  53. frozen crank pulley bolt / 20R
  54. 81 alternator problems
  55. my '79 project truck
  56. truck died need help
  57. Will an 81' 2wd p/u bed fit a 4wd?
  58. I got my truck stuck... finally
  59. Shopping Time, but where?
  60. 1981 4x4 need interior gear shift boots
  61. Changed the distributor drive gear!
  62. 1981 toyota transmission shifter help, can you figure it out?
  63. need photos of custom made 79-83 center console
  64. rebuild question....
  65. 87 22r into an 81 pickup
  66. 22r curved water pipe
  67. 1985 axle into a 1982 truck??
  68. Need Pictures of 79-83 truck with 3" Rough Country Lift
  69. Valve Adjustment Cost?
  70. crank shaft
  71. Best place to buy window channel and door panels?
  72. Smog problems with weber 32/36 or 22r carb on 20r motor?
  73. got new tires now i need more room
  74. 81-82 timing chain replacement
  75. 27 years with this girl. Longer than the wife.
  76. Looking for a 2WD transmission answer
  77. Help: 1981 22r guages quit working
  78. Christmas came early in my search for fix it parts!
  79. l52 tranny in a 81 pickup
  80. I searched for years and the wait is over - 1982 1st gen is MINE!!
  81. 81 4x4 tranny
  82. 83 No tail/dash lights
  83. distributor drive gear help!
  84. what do i need to complete my 4 inch lift??
  85. Power Steering Question
  86. toppers for long bed 1st gens??
  87. Barn Find question
  88. replacement floor pans?
  89. 83 Pickup Idle and Stall Problems
  90. paint scheme??
  91. front end steering questions.
  92. 79 charging system blues.
  93. Strange popping noise...
  94. Any fix for a slow / non respnsive tach?
  95. rear lights need help guys
  96. Help my 22r turns over but wont start
  97. 82 toy need advice....
  98. 88 cab swap on a 83?
  99. First Gen Four Door???
  100. De-Smogging an early 22R
  101. Used engine questions
  102. found chipped distributor gear tooth, advice please
  103. Post your gas mileage 1st Gen Truck (79-83 ONLY!!)
  104. t-case rear output shaft
  105. New guy with fuel pump questions
  106. weber carburetor
  107. Front Brake Line Bracket With No Backing Plates
  108. One approach to making a 1st Gen 4x4 double cab
  109. 83 timing cover bolt question..
  110. 81 2wd carb
  111. Gearing
  112. Will a 91 22re starter fit in an 84 22r???
  113. vacuum disconnect and timing
  114. cutting a 1st gen bed
  115. small cooland drip under the thermostat housing?
  116. 91 Pick up seats.
  117. Vibration from Transmission?
  118. 1st gen guys, help me locate these parts!
  119. Dropping fuel pressure
  120. Need help or info on spare tire tool.
  121. Water inlet neck leaking
  122. 81 Longbed Build up (Slow)
  123. '81 clutch problem
  124. '83 square driveshaft?
  125. idle problems
  126. 79-83 parking light lense part numbers
  127. 83 Timing R&R now marbles in blender noise "VIDEO"
  128. Newb and new parts questions
  129. 79-83' J-arm for sale
  130. 83 22R AC assembly removal. Can I? should I?
  131. 81 4x4
  132. 81 22R Vacumn advance question
  133. weather stripping
  134. Noise that seems to defy logic. Really worried.
  135. 81 4x4 will not stay running
  136. swapping long box for short box
  137. Transmission questions
  138. 1983 HAC valve connection help, please.
  139. Fuel pump!?!?
  140. front seat replacements
  141. Shlobeck's Labor of Love
  142. Topic: 81 4x4 steering problem
  143. Wrecked my truck
  144. New to me 80 hilux 4x4
  145. where to mount brakeline off the caliper
  146. Did a couple of little things to my truck.
  147. frame swap 82 pickup
  148. 81 toyota 4x4 smog questions
  149. 20R Cali emissions, Idle issues, complicated
  150. L45 or G52 ??????
  151. New bumper build and turn signal relocate
  152. Blower Motor only working on low help!
  153. The 82 Trekker just got all new rubber fuel line and a fuel filter..
  154. What years
  155. What alternators fit stock on a 79?
  156. driveshaft rebuild??
  157. 83 4x4 stock height??
  158. need some axle help
  159. dual ? and 4.7 ?
  160. 1st gen cooling system hose etc parts, possible sticky?
  161. 79 toy got a few q'
  162. 1979 Toyota Pick Up with over 500,000miles.
  163. double knuckle front drive shaft
  164. Leaf Spring Replacement
  165. Hello All! New to YotaTech. Here is my babe... my '82.
  166. random alternator light
  167. "Hey Corey, where is my thread?"
  168. Here's some recent pictures of my 81
  169. 1980 Truck power "pulsing"
  170. old style hose clamp question
  171. 81 running like crap
  172. Stock Rear Spring Hanger Bolts
  173. Front driveline mods?
  174. 83 headlight help please!
  175. Lesson learned about cooling systems!!
  176. 22R vs 22RE plug wires, cap and rotor?
  177. idle issues
  178. I gave the Trekker a bath today
  179. '83 Clearance problems
  180. 22r oil pressure specs
  181. 81 Leaf Spring Problem
  182. A few 2wd transmission and suspension questions
  183. Baja edition 82 4x4?
  184. 1979 4x4 vs. 1982 4x4 pick-up, what will swap over?
  185. Shackle Question
  186. Aftermarket Tach light wiring question.
  187. 1979 Limited Edition Model
  188. Power Steering
  189. W56 tranny swap
  190. 82 cooling system diagram / hose part numbers or descriptions?
  191. difference b/w 4x4 and 4x2 fenders
  192. Update on 82
  193. The *cough* cost of restoring an old truck...
  194. Rolled my short bed
  195. Weber carb question, Who sells them?
  196. What it may look like once its clean.....
  197. 82 pu shifter
  198. New here, and new to me 81 4X4
  199. almost over heating
  200. First trip of 2010
  201. Help with making 37's fit
  202. Temperature gauge/sending unit
  203. big brake upgrade Q's
  204. 81 5 speed getting stuck
  205. Trekker owners, does your back hatch lock use a different key?
  206. 22R won't start
  207. HEAD bolts torquem HOT?
  208. 81 stock gears?????
  209. Help! starting problem after HG change
  210. first ever rebuild
  211. 1982 4x4, rear end input loose?? what do you think, bearings or what?
  212. 4 speed shifter linkage question
  213. gear swap
  214. replacing vaccum hoses etc, need a hand and opinions
  215. My "new" project '80 Toyota - transmission/clutch question
  216. 1982 Trekker, driveline vibration?
  217. brake drum help
  218. AC UNIT coming along...i got pics
  219. alternator
  220. automatic to manual swap?
  221. Power Steering Conversion NEED PICS
  222. Seats?
  223. 22r timing
  224. '83 yota pickup back shaft yoke question
  225. My 83' aint doin so well....
  226. 1982 22r mechanical fuel pump question??
  227. my clutch blew up and im on a hill in reverse can i take tranny off in reverse?
  228. my 83
  229. sloppy tranny
  230. lug pattern
  231. Quick Question on Headers
  232. dash board recovery
  233. 82 4x4 advice
  234. Reunited after 27 years
  235. 83 yota pickup dashboard
  236. Got my 22RE parts today
  237. junk yard find
  238. Electrical Help on my 1980
  239. vented rotor swap
  240. ifs rear
  241. Vented rotors..
  242. 1983 22r wont idle correctly, Please HELP!!
  243. HELP head gasket "what have i done!"
  244. newer cab on 1st gen frame??
  245. Help!!! No spark!!!
  246. 83 LWB flatbed
  247. Wiper troubles on 81
  248. Will this dash work in my truck???
  249. Gear wear?
  250. Mystery intake manifold. Anyone recognize this
