Pre 84 Trucks 1st gen pickups
Changed the distributor drive gear!
Old Mar 25, 2010 | 04:02 PM
95yoda's Avatar
ok so some of you may know I was going to change the dist drive gear due to a tooth getting chipped off in the accident about 6 weeks ago, well got the new gear and took the old one out and it went pretty smooth! just had to lossen the fuel pump and pull it out an inch or so so that annoying arm was not in the way, and then pulled the dist out then put it all back in and it was done! and an added bonus!!!!! the chipped tooth was right in the little puddle of oil that that hidden timing cover bolt is it! fits the chip like a puzzle piece! im happy!
oh, checked the timing and it seem just fine! maybe cuz it only has 54k on the engine or someone did it before I owned it who knows, but it was fine.
oh, did all this outside in 38 deg weather, hardcore hahaah
Old Mar 25, 2010 | 04:11 PM
toyota4x4907's Avatar
I changed the radiator in my '93 single cab two winters ago at -25F. I was outside, no garage....
oh and good job
Old Mar 25, 2010 | 04:33 PM
slacker's Avatar
curious as to how the gear "chipped" in the first place ?
this would concern me the most !!
Old Mar 25, 2010 | 05:35 PM
95yoda's Avatar
did you see my accident thread? the force of the radiator and top core support rail smashing agianst the distributor forced the dist shaft to crack/bend back in turn chipping a tooth off the drive gear, the driven gear was fine. so now new drive gear and distributor, along with a lot of other stuff ive done in the last 6 weeks.
Old Mar 25, 2010 | 05:39 PM
95yoda's Avatar
oh I just re read my first post haha I did not mean to say the timing, I ment to say the valves haha I checked the valves and they seemed fine to specs, maybe due to the low miles? or someone did them before I had the truck? ive only put 4k on it.
Old Mar 26, 2010 | 03:20 AM
Gov't Mule's Avatar
Where did you end up getting the drive gear???
Old Mar 26, 2010 | 06:42 AM
95yoda's Avatar
My friend has an ebay account and we found it on there. its lightly used orig. piece off an 84. less then half the price of new!
Old Mar 26, 2010 | 07:20 AM
83's Avatar
83
Sweet. Glad you got it figured out. I remembered I was supposed to check my FSM for somebody...and it was probably you to help with that gear. Glad you got it figured out!
Old Mar 26, 2010 | 12:36 PM
95yoda's Avatar
yup, I read the valve cover tq spec is 5.5ft lbs?!?! that seems wayy to light? and read the oil pan spec is 4lbs? that is like hand tight? mines more I know on both
Old Mar 26, 2010 | 01:19 PM
83's Avatar
83
Didn't realized the oil pan was so low...but yeah the valve cover doesn't need much torque.
Old Mar 26, 2010 | 03:15 PM
95yoda's Avatar
I did the pan and no way was I doing it to 4lbs?! just seems way to loose because when I took the pan down most of them were less then finger tight but the thing was stuck on anyway haha but dont wanna lose bolts!
Old Mar 26, 2010 | 03:42 PM
Gov't Mule's Avatar
I did 12 on my pan last time...FWIW.
Jun 1, 2021 01:51 PM
Ichneumon
Sep 27, 2015 04:21 PM
85run
Jul 8, 2015 11:20 PM
Jnkml
Jul 6, 2015 01:20 PM
