Pre 84 Trucks 1st gen pickups
A/C Help Please (I have searched and still need help)
Old Apr 28, 2010 | 04:57 AM
hijack's Avatar
I have a 1982 which i actually think is an 1983 4x4 SR5 long bed with all the bells a whistles. I am having trouble with the A/C on it, it use to work about a year ago and now it doesn't. I thought it might be the dash turn style switch but it seems ok, when the blowers are on and you turn that switch to engage the A/C it makes a relay click on the passenger side under the dash, my problem is i cant find the relay or what ever it might be. Can someone point me in the right direction please ?
Old Apr 28, 2010 | 01:25 PM
thebrick's Avatar
search for full service manual or fsm. have you tried recharging the system?
Old Apr 29, 2010 | 04:12 AM
hijack's Avatar
if i manually engage the A/C on, it works fine and there is an appropriate amount of r134 in it, the wire that goes to the A/C pump is not getting any power when the switch is turned on, so i am trying to find were that wire goes without tearing into the harness to much.
Old Apr 29, 2010 | 08:33 PM
1981Toy4X4's Avatar
There is a small black box up under the dash on the passanger side. You can get to it very easily, you can open that box from the right side(a plastic end cap snaps on and off) take that circuit board out and visually check for "cold" or broken solder joints....repair if necessary. If all looks good there it is most likely the switch on the dash that is not making good contact and keeping the compressor engaged. Hope that gives you a start.
Old Apr 30, 2010 | 05:06 AM
hijack's Avatar
thanks guys for the feedback and i checked the board and it looks ok to me, if it is bad were can i find another one ? and the in dash switch could be bad but i think the in dash switch goes to a relay right ? if so were is that relay cause i hear a click but cant find it.
Old May 2, 2010 | 07:49 PM
1981Toy4X4's Avatar
The relay is actually on that circuit board if I remember correctly. To replace you can check the dealer ($$$) or try a Toyota specific wrecking yard for both the switch and the board. Keep us posted.
Old May 6, 2010 | 03:59 AM
hijack's Avatar
Ok so i wont be getting one from the Dealer cause they want $384.88 for that board. The indash switch is only $28 something, i will be looking in the junkyards for one this weekend. I also was wondering why i cant run a switch to a relay that manually engages the A/C clutch ? the same type of thing that runs most KC lights.
Old May 8, 2010 | 09:34 AM
abeD85flatbed's Avatar
the amplifier board also kicks the idle up a bit to compensate for the increased load on the engine. I bypassed mine for a while and put up with it, but finally replaced the dashboard switch as well as the board and that fixed it. 92 22Re. If the board is not doing any of these things and the idle issue isn't a problem, than run the relay as you suggested.
MO transplant
Apr 23, 2023 11:58 AM
Sarcazmo
Aug 15, 2015 08:22 PM
hmmhoyhoy
Aug 12, 2015 10:33 AM
stock87yota
Jul 31, 2015 10:08 AM
TURBOrunnerNM
Jul 20, 2015 08:31 AM
