Pre 84 Trucks 1st gen pickups
timing spec
Old Apr 26, 2010 | 09:31 AM
86yota321's Avatar
timing spec
Hey guys, I have an 81 or 82 motor in my 86 truck and was wondering what the timing is supposed to be set to on those years. Right now it's at 8* but seems a little fast. I've tried searching and can't find anything.
Old Apr 26, 2010 | 12:47 PM
thebrick's Avatar
http://www.ncttora.com/fsm/index.html
Old Apr 26, 2010 | 03:47 PM
slacker's Avatar
8* BTDC is correct .. the newer units are @ 5* ..
with a little wear on the gears , i always start @ 8 and tune it by ear
Old Apr 27, 2010 | 02:28 PM
skooterbumm's Avatar
i run my carbed engine at 8 and if i get good gas 10. no pinging or detonation
Old Apr 28, 2010 | 10:59 AM
86yota321's Avatar
Thanks guys.
Old Apr 29, 2010 | 06:27 AM
stokesdead's Avatar
8*???? I thought that my FSM says 0*? I am certain the FSM says that actually. Are you guys disabling the vacuum advance to set the timing? or leaving it connected? I have been trying to get this engine to run better and perhaps I have the timing set wrong.
Old Apr 29, 2010 | 06:48 AM
86yota321's Avatar
I can't remember where I saw it now but the specs were 8*, 5* and 0* for differernt years. I know that 86 and up are supposed to be at 0. I'll try to find it again because it had a breakdown for the different years. Yes, I disconnected lines from vac advance and plugged them when I set mine. 8* seems to be working good for me so far.
Old Apr 29, 2010 | 08:35 AM
stokesdead's Avatar
anyone have a definitive answer on where the timing needs to be set?
Old Apr 29, 2010 | 09:44 AM
86yota321's Avatar
Found this:
75-82 is 8 degrees BTDC
83-84 is 5 degrees BTDC
85 22R and 22RE 0 degrees TDC
86-87 22R 0 TDC
22RE and RTE 5 degrees BTDC
http://forum.ih8mud.com/79-95-toyota...timing-22r.htm
Hope that helps some
Old Apr 29, 2010 | 01:46 PM
Gov't Mule's Avatar
8 degrees BTDC...that's as "definite" as it gets.
bigjstang
Jun 2, 2025 03:56 PM
Eggslinger
Jun 8, 2019 03:32 PM
Sep 4, 2015 09:27 AM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
