Pre 84 Trucks 1st gen pickups
need some axle help
Old Jan 27, 2010 | 10:51 PM
ajoebob's Avatar
need some axle help
well that high horse power 22r finely got me.
anyways on to my ? when i pulled the axle out this is what i seen.
you see the ring loose in the center? the axle busted it loose and bent the hole thru the center of it some. what was it there for and is it needed? i'm thinking about swaping axles for now but i need to get this one back up and ready to go. any ideas
Old Jan 28, 2010 | 05:20 AM
dropzone's Avatar
Fossilized
looks like the the inner axle seal-helps to keep the knuckle grease from looking milky and still looking like grease. keeps the diff gear oil where it needs to be.
nice job on the birf
Old Jan 28, 2010 | 01:48 PM
ajoebob's Avatar
its not the seal. it did rip it out too but the ring i'm talking about is an all steel ring that was in the axle tube(in past the axle seal) i think it was to halp aline it when to put it in but not sure.
i never would of thought i would brake on runing 32's but it did last 28 years. in a few weeks i will have my new 36's we will see how it likes them.
Old Jan 28, 2010 | 03:34 PM
slacker's Avatar
it's the oil splash shield ..
Old Jan 28, 2010 | 04:15 PM
ajoebob's Avatar
That makes sense. Now do I need it and is there a way to fix it?
Old Jan 28, 2010 | 05:10 PM
slacker's Avatar
3rd member needs to be removed .. and then you can re-install it if you wish .. it keeps the oil in the "pumpkin" and not in the tubes .. I think there a good idea , so I would re install it
Old Feb 4, 2010 | 12:56 AM
ajoebob's Avatar
heres the other half of my berf
heres the ring i was talking about
it use to set around 1" back from the axle seal i left it out.
TheBFA
Feb 15, 2020 06:55 AM
live4soccer7
May 11, 2016 06:52 PM
JookUpVandetti
Sep 30, 2015 08:58 AM
Cycles
Sep 29, 2015 06:37 AM
Toys4parts
Sep 26, 2015 01:56 PM
