Pre 84 Trucks 1st gen pickups
Front driveline mods?
Old Jan 21, 2010 | 10:44 PM
IanCain's Avatar
I lifted my truck around 7 inches to clear 35s, i used 4 inch springs and 3 inch shackles. Now my front driveline binds. Ive heard several different opinions on how it can be modified to work but i want to do it right. Its a 1979 toyota. Any insight would be truly appreciated, thanks.
Old Jan 25, 2010 | 10:18 AM
4rnr's Avatar
lower it about 5 inches.
Old Jan 25, 2010 | 06:32 PM
tc's Avatar
tc
4" spring + 3" (over stock) shackle = 5.5" lift
Binds how - at normal height, or droop?
What's the rest of your setup?
Generally your options depending on how it's binding:
- modify the double cardan joint
- cut/rotate the knuckles to aim the pinion at the tcase and reset the caster
- go to double tcases
- switch to high pinion diff
- lower the lift
- combinations of the above
Old Jan 25, 2010 | 06:57 PM
myyota85's Avatar
hey ian i have a 79 also 4 sale now thoe but i got it in 2000 and i lifted just like u but in 2002 n e ways the stock drive shaft would come off every time the trucked flexed (especially when i had to slam on the brakes in traffic) the truck would go down then it would catch the ends of the drive shafts id have to get under the truck and kick them apart. so i took it to a drive shaft place and he extended it 4 me maybe 3 inches but not sure how long! never had a problem since then thoe. hope this helps let me know if i can take a measurement or somethin.
Old Jan 25, 2010 | 07:10 PM
slacker's Avatar
you'll need to lengthen your front drive shaft .. chances are , if you havent done so , your running on limited splines
Massmayhem247
Jul 18, 2015 05:46 AM
icentropy
Jul 11, 2015 07:21 AM
Nickdigg
Jul 7, 2015 06:04 AM
toyoda8488
Jul 5, 2015 10:18 PM
