Pre 84 Trucks 1st gen pickups
Blower Motor only working on low help!
Old Jan 31, 2010 | 01:06 PM
shmitty's Avatar
I have and 81 pickup and the blower motor only works on low i was wondering if there is a resistor pack that could be causein the problem if so does anyone know where it is??
Old Jan 31, 2010 | 01:22 PM
eric-the-red's Avatar
This might help
http://www.4crawler.com/4x4/CheapTricks/Blower.shtml
Old Jan 31, 2010 | 03:49 PM
slacker's Avatar
yep , sounds like the resistor ..
it's held in with a single screw (philips head) on the drivers side up by the emergancy brake handle ... it has a 4 prong wire plugged into it ..
Old Jan 31, 2010 | 03:52 PM
shmitty's Avatar
Thanks man ill check it out when this snow we have clears up! do you know where i could get another one?
Old Jan 31, 2010 | 03:56 PM
kiyobrown's Avatar
check the junk yards til you find one that is still intact. or, theres always ebay.
Old Jan 31, 2010 | 04:31 PM
slacker's Avatar
as well as the dealer ..... this is a VERY fragile part and should be treated as such !
Old Jan 31, 2010 | 04:34 PM
Fink's Avatar
SEARCH would have instantly given you your answer.
Fink
Old Feb 1, 2010 | 05:20 PM
shmitty's Avatar
well thats alot of help maybe ill try that sometime! and for everyone else thanks for the advice i found one at the local parts store twenty bucks works like new!
Old Feb 2, 2010 | 07:10 AM
Ilovemountains's Avatar
Sounds like my problem too, Ive got high and middle but no low, the same thing happened on my 88 and it was the resistor, I just havent made it that far in the 82!
Old Feb 2, 2010 | 07:53 AM
83's Avatar
83
Mine only works on the last two, high and the one just before it. I keep meaning to replace the resistor but it's just not high on the priority list, since it does still work at least.
Old Feb 4, 2010 | 04:30 PM
Fink's Avatar
If you don't I assure you your time here will be short-lived.
Fink
Old Feb 4, 2010 | 04:36 PM
Gov't Mule's Avatar
Ditto
Team420
Jan 12, 2021 04:57 PM
voiddweller
19
May 2, 2016 09:10 PM
bigblue82
10
Jul 6, 2015 08:27 AM
gog1968
Jun 22, 2015 05:55 AM
bobbybouche
Jun 18, 2015 10:22 AM
