Pre 84 Trucks 1st gen pickups
Power Steering Question
Old Mar 11, 2010 | 12:27 PM
beswa's Avatar
Hi i have a 81 pick up just wondering if a 86 power steering setup would work with my truck
thanks dave
Old Mar 11, 2010 | 01:04 PM
83's Avatar
83
Not without modification/fab work.
Old Mar 11, 2010 | 01:22 PM
greaseyknight's Avatar
Is it 2wd or 4wd? 2wd will swap (I did a 87 to 83 swap), 4wd will not as suspension system is different between 81 and 86
Old Mar 12, 2010 | 05:39 AM
83's Avatar
83
But the '86 has the IFS steering box, 2wd or 4wd, so he would need to weld it onto the frame, correct? I mean I know it will swap, but it won't be a "bolt-on" fit, he will need to do some fab work.
Old Mar 12, 2010 | 06:16 AM
According to the parts catalog, 81-88 2wd trucks use the same steering box.
and the 86-88 4wd use a different one.
The only problem I ran into swapping the power steering from an 87 2wd to 83 2wd, is that the manual steering shaft is a little bit long
Old Mar 12, 2010 | 08:04 AM
83's Avatar
83
Ok cool, that would be nice! Yeah, I think even in some of the first gen trucks, the steering shaft is different for power steering/non power steering.
My guess is that the 81-88 being the same is because even the first gen 2wd's had IFS? But going from any 2wd with power steering to a first gen 4wd without would be an issue? As in not a direct bolt on swap. But if you've done it already, you know more than me!
Old Mar 12, 2010 | 08:06 AM
DeathCougar's Avatar
The power steering setup will work no problem, MINUS the steering gear.
You would either need to A. get a new steering gear or B. switch to crossover steering and use the IFS steering box.
The steering shaft is also a different length, but the slip joint in the shaft should take up enough play. If not, just get a used steering shaft from the same truck.
Old Mar 12, 2010 | 01:20 PM
83's Avatar
83
Good to know!
Old Mar 23, 2010 | 02:39 PM
capekdw's Avatar
Can you use a power steering setup out of an 89-95 Toyota on an 83 with high steering? I'm assuming it shouldn't be a problem just looking for some verifacation thanks
what's up everyone new to yota tech
ps all pro and trail gear both sell a bolt on and weld on bracket for the ifs box, but it just as easy to make your own
Old Mar 23, 2010 | 03:07 PM
dropzone's Avatar
Fossilized
yes, 86-95 IFS 4WD steering box will work
glowz825
Jan 25, 2022 09:28 AM
tj884Rdlx
Aug 28, 2015 12:04 PM
keithporter83
Jul 24, 2015 07:37 AM
jon.r
Jul 11, 2015 03:34 PM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
