Pre 84 Trucks 1st gen pickups
Power Steering
Old Jan 15, 2010 | 09:36 AM
CrazyEye's Avatar
Power Steering
I have an 83 Sr5 4x4 Toyota, I was wondering if anyone knew what the stock power steering pump is capable of putting out in PSI. I was thinking with the right setup I could run full hydraulic steering for cheap. Any input on this is much appreciated.
Old Jan 15, 2010 | 09:59 AM
CrazyEye's Avatar
Okay I found the info I was looking for finally, if anyone is interested the stock pump puts out 1300psi at 1 gallon per minute. I think this is going to be possible.
Old Jan 15, 2010 | 10:33 AM
83's Avatar
83
Good! Yeah I think with most people that go hydro, they've also converted to highsteer and all that, but that's cool that these older pumps will work.
Old Jan 15, 2010 | 05:58 PM
dropzone's Avatar
Fossilized
from what I understand the stock pump does not put out enough pressure/GPM to cycle a full hydro steering system fast enough. That is even after modding the passages for more flow. I have seen some trucks on the trail with their steering looking like it is moving in slow motion.
A Howe, PSC or T-G full hydro pump moved 4-5x's the stock pump making the steering react faster.
Maybe Wabbit or 4crawler will chime in on this one.
Old Jan 15, 2010 | 08:37 PM
CrazyEye's Avatar
I was looking at the aftermarket pumps they only push around 1900 psi. But yes the flow is alot higher. I was thinking couldnt you just increase the rpm of the pump, and modify the passages as well? At high rpm I think the stock pump would do just fine but at low is where it would be slow reacting. I think by building a smaller pulley to make it rotate faster would make it flow faster. Am I correct on this? The way I figured, I could build a hydraulic with a surface area of 1.750 and that would generate around 2100 pounds of force at 1300 psi. The question is how much force is needed? I understand that it would be different in different scenarios. The smaller I make the surface area the quicker it would react there for it would require less fluid. Making the 1GPM sufficent enough to get the job done.
I am hoping the experts will chime in, come on Wabbit and 4crawler. Teach a 24 yr old your wisdom, I like to learn.
Thanks for all the input on this one guys...
Old Jan 15, 2010 | 09:02 PM
CrazyEye's Avatar
I was thinking, what is the maximum rpm that a stock toyota pump could run at and still be stable? Anyone ever experiment with this? I would but I only have 1 pump, anybody want to send me a couple pumps for research?
Old Jan 15, 2010 | 09:18 PM
CrazyEye's Avatar
^^^ that was a serious question^^^ I am a machinist thats specializes in high energy hydraulics, pnuematics and robotics, I engineer and build. I am sure I can figure out a way to get a full hydraulics steering system to work without costing you an arm and a leg. Just trying to help the yotatech community here folks.
Old Jan 15, 2010 | 09:23 PM
CrazyEye's Avatar
I would probebly make my own high steer system to work with this setup.
Thanks for the input.
Any suggestions, I am wide open for any comments and suggestions, or bashing...
Old Jan 16, 2010 | 05:55 PM
dropzone's Avatar
Fossilized
not so much the PSI but the amount of fluid moved.
Might consider searching the toyota folder on pirate
http://pirate4x4.com/forum/forumdisplay.php?f=12
though not specific to toyota this article on hydro steering will help:
http://pirate4x4.com/tech/billavista...ing/index.html
Old Jan 16, 2010 | 06:03 PM
waskillywabbit's Avatar
Stock pump is 1 gpm at best. My full hydro pump is 4 gpm. IMO stock pump will NOT keep up no matter what you do to it. Hydro assist is pushing the limits and some folks get it to work right with a stock pump, some don't.
I've had manual steering (pump went out), power steering, hydro assist and full hydro and the first three suck by comparison when wheeling.
Zpd426
Jan 2, 2016 01:15 PM
delmert
Sep 30, 2015 04:34 PM
Up&Down
Aug 11, 2015 10:04 AM
toyoterferdayz
Diesel Swaps
Jul 27, 2015 05:25 PM
gmonnie123
Jul 26, 2015 02:44 PM
