Power Steering
Power Steering
I have an 83 Sr5 4x4 Toyota, I was wondering if anyone knew what the stock power steering pump is capable of putting out in PSI. I was thinking with the right setup I could run full hydraulic steering for cheap. Any input on this is much appreciated.
from what I understand the stock pump does not put out enough pressure/GPM to cycle a full hydro steering system fast enough. That is even after modding the passages for more flow. I have seen some trucks on the trail with their steering looking like it is moving in slow motion.
A Howe, PSC or T-G full hydro pump moved 4-5x's the stock pump making the steering react faster.
Maybe Wabbit or 4crawler will chime in on this one.
I am hoping the experts will chime in, come on Wabbit and 4crawler. Teach a 24 yr old your wisdom, I like to learn.
Thanks for all the input on this one guys...
I was thinking, what is the maximum rpm that a stock toyota pump could run at and still be stable? Anyone ever experiment with this? I would but I only have 1 pump, anybody want to send me a couple pumps for research?
^^^ that was a serious question^^^ I am a machinist thats specializes in high energy hydraulics, pnuematics and robotics, I engineer and build. I am sure I can figure out a way to get a full hydraulics steering system to work without costing you an arm and a leg. Just trying to help the yotatech community here folks.
Thanks for the input.
Any suggestions, I am wide open for any comments and suggestions, or bashing...
not so much the PSI but the amount of fluid moved.
Might consider searching the toyota folder on pirate
http://pirate4x4.com/forum/forumdisplay.php?f=12
though not specific to toyota this article on hydro steering will help:
http://pirate4x4.com/tech/billavista...ing/index.html
Stock pump is 1 gpm at best. My full hydro pump is 4 gpm. IMO stock pump will NOT keep up no matter what you do to it. Hydro assist is pushing the limits and some folks get it to work right with a stock pump, some don't.
I've had manual steering (pump went out), power steering, hydro assist and full hydro and the first three suck by comparison when wheeling.
delmert
Sep 30, 2015 04:34 PM
