Pre 84 Trucks 1st gen pickups
ifs rear
Old Dec 15, 2009 | 04:36 PM
rottenagenda's Avatar
ifs rear
haveing trouble finding info
what year ifs rears bolt up to a 1979 toyota pickup?
and mods or welding?
3rds bolt
Old Dec 15, 2009 | 08:03 PM
yota8083's Avatar
Your looking for an 86 to 89 ifs rear I believe but it is not a direct bolt in, at least mine wasnt. The spring pad is wider on the ifs rear and the axle housing is physically larger in diameter so your factory u bolts wont work, you will need to buy a flip kit. Also realize that when you buy said flip kit the top plate comes drilled for the narrower spring perches like what was on your factory axle so you will have to drll them out 1/4 inch each side. This leads to the next issue, shock mounts. Since your shocks mount the the factory u bolt plat (at least mine did) and now this is gone in favor of the flip kit you will have to relocate the shocks with different mounts. I did not have an e-brake on mine so I dont know if this would be an issue or not. That is all I can think of at the moment that you will need to take into account.
Old Dec 15, 2009 | 09:53 PM
85excab's Avatar
86-95 rear axles will work, except 90-95 4runners.
usu the u-bolts and u-bolt plate from donor truck.
buy the lower shock mounts from trail gear for the axle side.
http://www.trail-gear.com/shocks.html
front range offroad makes a solid axle widening kit to make it the same width as the rear axle too.
http://frontrangeoffroadfab.com/nfos...0b7d4baa90c2d3
Old Dec 19, 2009 | 10:38 PM
81redbluffyota's Avatar
From: I live in Red Bluff ca. Right by the Sacramento river
I just used my 81 mounting plate, till i get a flip kit. We tightened the u bolts with an impact gun, it bent the plate around the axle tube, not ideal, but we are positive its not coming off, and it still allows me to use my stock shock mounts.
Old Feb 8, 2010 | 05:38 AM
still alittle fuzz can anyone point me to a wrie up.
88sasturbotoy
Jan 30, 2026 01:57 PM
Flying91
45
Apr 11, 2024 04:39 PM
deepmarsh
Aug 6, 2015 03:44 AM
coffey50
Jul 28, 2015 10:55 AM
scottyg486
Jul 19, 2015 05:34 PM
