Pre 84 Trucks 1st gen pickups
81 22R Vacumn advance question
Old Feb 13, 2010 | 11:31 AM
81 4X4's Avatar
Why does the vacuum advance have two vacuum lines? When switching carbs, I've seen guys just use one, and plug other one, and then I've seen guys use both with a "T" into one line. What's the best way to do it? Thanks, Dean
Old Feb 13, 2010 | 11:47 AM
xxxtreme22r's Avatar
I think this was covered on here before, someone correct me if I am wrong please. The line furthest from the motor is controlled by a vsv which i believe supplies vacuum to the distributor when the motor is cold and retards the timing. The other line is the regular vacuum advance and comes off of manifold/carb vacuum. The ones you see that have removed the one line most likely have a Weber carb. The ones with the tee is defeating the vacuum advance and I would be surprised it even runs right that way.
Old Feb 13, 2010 | 01:58 PM
kdo58's Avatar
if you have a weber plug the inside one, and use the outside one for your carb.
Old Feb 13, 2010 | 02:24 PM
Originally Posted by kdo58
if you have a weber plug the out side one, and use the inside one for your carb.
the one closest to the motor? So I have the description in previous thread backwards?
Old Feb 13, 2010 | 03:51 PM
Gov't Mule's Avatar
Yeah....closest to motor (inner) goes to the carb....outer gets plugged.
Old Feb 13, 2010 | 04:04 PM
wow ok got to swtich things around on mine. updated previous thread of mine, reflecting the correct alignment.
kazuya2416
Apr 5, 2024 02:17 AM
oldirtydirt
Feb 23, 2020 09:30 AM
coleypull15
Nov 3, 2015 07:41 AM
tj884Rdlx
Aug 28, 2015 12:04 PM
88yodabasket
Jul 13, 2015 01:32 PM
