Pre 84 Trucks 1st gen pickups
Webber Carb questions
Old Apr 10, 2010 | 07:35 PM
CrazyEye's Avatar
I have a 83 SR5 Toyota 4x4. Powered by a 22r. It has a weber carb on it. Can someone tell me what carb I have? I hear people say they got a 32/36 and Im not sure what that means. Could someone clarify this for me? I also brought this motor and carb from Washington State at sea level. I moved to Flagstaff Arizona I am now at around 5200 ft above sea level. Which jets are best for this elevation? Just though some of you high altitude guys can point me in the right direction. Thanks.
Old Apr 10, 2010 | 08:57 PM
CrazyEye's Avatar
certainly not everyone is retarded as me on this subject....
Old Apr 11, 2010 | 06:39 AM
skooterbumm's Avatar
there is a number stamped into the bottom of the carb. The bad part is its on the valve cover side and hard to see. The easy way to tell is look down inside if the venturies are diffrent sizes its a 32/36. if they are the same size then you will have to get the number. Also there are a few 32/36 carbs.
Old Apr 11, 2010 | 08:47 AM
CrazyEye's Avatar
I will check into that today. Thank you..
Old Apr 11, 2010 | 09:38 AM
CrazyEye's Avatar
Ok so it looks like i got a 32/36, and of you high altitude guys know what jets to run at 5200 ft above sea level. What works best for you?
kazuya2416
Apr 5, 2024 02:17 AM
daddio
Aug 9, 2015 07:17 PM
tomczaksdiesel
Jul 26, 2015 10:35 PM
Yota.Jay
Jul 23, 2015 08:08 PM
