Pre 84 Trucks 1st gen pickups
Water inlet neck leaking
Old Feb 21, 2010 | 11:44 AM
aadown1214's Avatar
Exclamation Water inlet neck leaking
Hi all, I swapped my t-stat and gasket yesterday, now it's trying to leak again. I swapped another gasket this morning, and it's better, but still making me wonder. I did notice that the cut-out for the t-stat looks like it may have once had a rubber o-ring or something.......could this be part of the problem? Also, trying to remember, the t-stat goes under the gasket right?
Old Feb 21, 2010 | 11:58 AM
aadown1214's Avatar
I keep thinking that the only explanation is maybe the intake or the inlet neck may be warped?
Old Feb 21, 2010 | 12:08 PM
Teuf's Avatar
well a gasket would take up any irregularities. mm I thought gasket was below Tstat. you could try one above and below? Or find n O ring for that groove. Don't yah hate little probs like that
Old Feb 21, 2010 | 12:25 PM
86tuning's Avatar
Take your waterneck and a piece of sandpaper and flatten it out. Lay the ~80 grit paper on a FLAT table and carefully sand the water neck til it's level.
I'd use the genuine toyota thermostat and gasket for best results.
Old Feb 21, 2010 | 12:27 PM
buckz6319's Avatar
my t-stat came with a large rubber O ring that fits around the out side of the t-stat, then install the it, should not leak and if it does then maybe a cracked housing
Old Feb 21, 2010 | 01:26 PM
aadown1214's Avatar
I just fired it up and took it for a drive, outside of the seal looks a little wet, but not dripping on outside of intake manifold, hopefully won't start leaking anytime soon. I've never gotten a t-stat that comes with the rubber O-ring, interesting.
Old Feb 21, 2010 | 01:53 PM
buckz6319's Avatar
I can remember the days when I used to make my own t-stat gasket from gasket material.....you can still buy that at the auto parts store
since your in Dahlonega I bet there are a lot of places to wheel?
Old Feb 21, 2010 | 02:42 PM
aadown1214's Avatar
Oh yeah, just got to watch out for the game warden in the natl. forrests. A lot of the other trails are closed for a few years, such as Teleco
Old Feb 21, 2010 | 03:38 PM
buckz6319's Avatar
cool.....if I can get my old yota up to par?....I would take it off road for the first time since I bought it in 08
TJWilly
Jul 31, 2015 02:05 PM
jjrbus
Jul 19, 2015 02:06 PM
Jonny246
Jul 12, 2015 04:51 AM
horunner1x
Jul 10, 2015 06:33 AM
Avenged
Jul 9, 2015 07:55 AM
