PDA
View Full Version : Pre 84 Trucks
Pages : 1 2 3 4 5 6 7 8 9 10 [11] 12 13 14 15 16 17 18 19 20 21 22 23 24 25
  1. 21R Motors in Hilux/Trucks?
  2. new u jonts?!
  3. Sourcing new/old Toyota parts online
  4. L series transmission clutch fork/throw out bearing question
  5. handling problems 82 4x4
  6. 79 toyota truck front driveshaft
  7. 1982 4x4 new owner, transmission question
  8. 79 4x4 pickup 20r carb problems
  9. 1.0 vs 1.4 KW starter motors-- interchangable?
  10. High steer clearance question
  11. 82 4x4 help please
  12. idle speed and truck dies
  13. 2ND or 3RD GEN BED ON A 79-83
  14. transmission
  15. 4th and 5th gear question
  16. Emissions vacuum spaghetti`
  17. IDEAS wanted for replacing carpet in front cab of 82 Toyota pickup with thick rubber
  18. What other bucket seats fit the 83 and older Toyota pickup truck?
  19. '83 oil leak
  20. front axle bogging it self down
  21. Testing bad headlight connection to relay [1982 Pickup]
  22. 82 toyota pickup front endd shimmy still there after rebuild
  23. A/C compressor mount
  24. Ring gap orientation and the 83 FSM
  25. L50 trans
  26. Throwout Bearing
  27. 1982 yota pickup running rich
  28. Pillar Gauge Pod
  29. "Low End Rod Knock"
  30. Who's replaced their shifter boots?
  31. Little Problems
  32. front axle question...Probably a stupid one..:)
  33. New(ish) 83 4X4 Owner!
  34. Spindle on 81
  35. 83 Randomly Stalls. Help!!!!!
  36. Pre '79 2wd toyota people!!
  37. Any way to tell if my 3rd has s solid pinion spacer or crush sleeve?
  38. Name that front end clunk...
  39. weber 32/36 inconsistent idle speed
  40. 87-89 4runner seats in first gen
  41. Need some help with a 20r
  42. 1982 Toyota SR5 Fuel tank?
  43. 79 pickup 4x4 short bed fuel tank
  44. Headlight issues
  45. Exhaust Hangers
  46. Leaf springs
  47. Help with truck identification ,.. 1982 Toyota fiberglass tail
  48. Weber Style Air cleaner for Stock Carb?
  49. Rebuild leaf springs?
  50. Improper anti-rattle clip installation led to brake pulsation?
  51. Headlight voltage supply wire
  52. Ifs or leaf spring suspension
  53. Transfer Case for L43
  54. Turning an 84-85 LWB frame into a 1979-83 frame
  55. Shake/ Death Wobble
  56. 1982 Vaccuum advance diaphragms?
  57. 83 Yoda 3"leaf spring lift
  58. smog legal header for CA 22r
  59. 22R Desmog Tutorial
  60. Help me sort out this basket case 81!
  61. FJ 80 tie rods
  62. HELP PLEASE: Questions about replacing fuel pump on 1982 22R
  63. Damn left over parts
  64. Intro post, 82 pickup carb questions :)
  65. 1982 Trekker crash test video. Heartbreaking.
  66. 83 Pickup T-Case Chirping
  67. 82 toyota SR5 bucking/surging at certain grades
  68. Front & rear bearings behind pinion oil seal?
  69. Where to buy positive battery cable for 82 Toy Pickup?
  70. L52 trans flush?
  71. What to do with rotten frame?
  72. inertia switch on 80 please help!!!!
  73. How much does my cab weigh?
  74. 1982 SBC Swap
  75. Making a toyota camper pass smog in California
  76. 1982 stock fuel pump pressure?
  77. Cool Aussie First Gen Conversion
  78. Building A Bumper For The Truck
  79. Is the hood, front bumper & seats interchangeable between 82 & 84 Toy pickup trucks?
  80. Plastic bedliners
  81. 78 p/u loses power and misses on acceleration
  82. HELP: Must swap rear axles between 82 5 lug 1/2 ton dually & 84 6 lug 1 ton dually
  83. HELP: 82 22R won't start without spraying carb but then runs great all day after that
  84. 1982 DRIVELINE/TRAN VIBRATION ONLY IN 5th @ CERTAIN RPMS
  85. Is this a Doug Thorley Header for a 22r?
  86. HELP! Need to make wiring harness for 22re in 83 pickup
  87. Defective Igniter Assembly
  88. 79 O2 sensor
  89. Steering unstable and differential question
  90. v6 3rd Front Solid Axle
  91. I need some help in NorCal!!!
  92. front drive shaft cv on rear drive shaft ?
  93. Yota doublecab 83'
  94. Side Draft Carb Kit
  95. Transfer case question
  96. 1982 Pickup L50/52 to W series Transmission ???s
  97. Brake and clutch brackets
  98. going stock again
  99. oil light keeps coming
  100. Heater issue
  101. Heavy duty axles and/or bearings for pre-79 trucks?
  102. Ring gap for 1982 22R
  103. 81 Toyota 4x4 and parts replacement
  104. NEED HELP 84 pu 22r cold mixture heater assbmly
  105. 4wd emblem
  106. Gen 1 Truck Box – Storage Box – Tool Box – Pics anyone?
  107. Old seat needs replacement. Honda Civic? Why not
  108. Charging problems 76 20R
  109. Best online parts store?
  110. Type of oil in W5 transmission, and one ton rearend?
  111. 1984 pu auto trans weber conversion
  112. Gear oil in engine
  113. Front and rear glass
  114. Upgrading to aluminum rockers on 82 22r. Can I reuse the steel adjustment screws?
  115. LC spiral adapter install questions
  116. rear yoke loose...not pinion...
  117. A/C wire question
  118. Help IDing Wire
  119. What is this?
  120. L50 input bearing
  121. ECM removal/1983 Canada emissions
  122. Helping with heavy load?
  123. heat issues
  124. 20r ignition help
  125. Toyota 4x4 axles
  126. Thoughts on a good exhaust setup?
  127. tacoma rear elocker housing swapo
  128. 81 22r put in 87 sr5
  129. Clutch or cylinder problem
  130. Water in my Fuel WTH?!?!?
  131. 1st Gen Truck (1981) LED dash lights swap
  132. 83 fan/vent problem
  133. 1978 2wd restore/build
  134. Buying a "new" first gen!
  135. Help! 20R makes tapping sound. Driving my crazy.
  136. has anyone ever seen this dashboard option on an 83 before? (digital clock)
  137. Trans to transfer coupler
  138. '79 Pickup Not Getting Spark --- Help?
  139. First gen pickup weather seals needed!!
  140. 1971 Toyota Hilux project
  141. short bed long bed drivetrain difference?
  142. 1976 20r acting like its out of fuel
  143. Strange Starting Ritual
  144. Noob transmission ID
  145. 1982 4x4 p/u wheel availability ??
  146. Flex your 1st Gen Pickup **83 & Earlier Flex Pics ONLY**
  147. Setting tire pressure with chalk test
  148. 83 yota 4x4 clutch replacement!!
  149. Transmission movement!
  150. 82 Parking Brake and Battery Light On! HELP!
  151. Light blue Pickup in Tampa
  152. Damn alternators....
  153. air injection on an 83 22r???
  154. A swap question
  155. Replacement spring bolts
  156. Capacitor on back of alternator case?
  157. 81 22r slow start when hot
  158. bed liner "mat"
  159. EGR sys causing a vacum leak ??
  160. WOW, OMG, Most amazing all ORIGINAL 1st gen Toyota in the worldta ina the world
  161. charge light come on for overcharging?
  162. 83-84 EFI build questions
  163. Fuse box replacment.
  164. Will a '85 dash fit in a '79-'83?
  165. 1980 toyota power steering swap..
  166. Carb Set Up Picture! POST HERE!!!
  167. 81 SR5 4x4 non working odometer recent
  168. lets see your bucks in truck!!!!
  169. short bed or long bed 1st Gen?
  170. Drum brake shoe problem
  171. Vacuum Advance/ Timing Question
  172. T-Case supposed to spin while trans in N?
  173. 7 foot topper on 7'2" bed-"molding the gap!"
  174. My 22R Rebuild - KawaZX636
  175. 82 4wd 5SPEED?
  176. general questions about 81 pickup
  177. HIGH oil pressure
  178. Yay: New 1st Gen owner- 82 4WD
  179. 1983 Toyota Pickup FSM Download!
  180. Replacement stereo
  181. Transmission Swap in 1980 Automatic to manual
  182. GM Alt install problems
  183. Bell housing to block bolt size and whats that thing?
  184. 22r miss
  185. Weber Tech/Tuning for newbies and tuning
  186. weber 32-34 dft? will it work?
  187. 20r manual fuel pump clearance issue
  188. Making the Yota earn it's oats!
  189. Sr5 cluster swap
  190. 22r hooked up to 20r harness and regulator putting out too many volts
  191. Oil consumption Question
  192. 1978 Toyota Motorhome Axle Flew Out
  193. Is this suppose to be that close to the thermostat houseing?
  194. How do I install the throttle linkage on weber?
  195. Timing screwed up.
  196. What is this part?
  197. horn buttons in steering column
  198. 1979 20R 2WD project.
  199. Odd noise after doing some work 22r carb'd 1982 4x4
  200. Whats the plastic thing under my intake?
  201. Skyjackers now or wait or OME
  202. 83 22r wont idle after driving
  203. 2wd cab on 4wd?
  204. Power Steering conversion for an '81 4x4
  205. Clutch Pack
  206. tonneau cover??
  207. Has anybody dealt with NW CylinderHeads??
  208. where to find parts..???
  209. New radiator and HG?
  210. Number of 1979-1983 Trucks-poll: what year do you own?
  211. '81 22R sudden missing/poping/lack of power
  212. How do I clean carbon from these?
  213. cat/exhaust problem?
  214. Couple 3 questions on my 81
  215. 81 2wd tranny in 82 4wd
  216. Massive Oil Spray
  217. Weight specs of 81 JT4
  218. Are 1979 20r 2wd manifolds unavailable?
  219. Where to order the REAL Weber CARB?help
  220. Resurrecting an 80 that sat for years
  221. My 1979 20R 2wd build process (pics)
  222. are all head gaskets created equal?
  223. 20r Long Block Purchase?!?
  224. somewhat urgent electrical problem
  225. 22r 2.25 pipes!!???
  226. Clutch probs
  227. blows cold on vent
  228. 1982 ECM Diagnosis
  229. First-gen dashboard removal
  230. rear springs 48" and 51"
  231. How do I get rid of Vacuum lines? 79 20R
  232. Is this to much
  233. Carb Adjustments
  234. Carb vacuum ports?
  235. 1980 4-5 speed swap
  236. 82 4x4 weber running rich
  237. I think i have a problem
  238. Headlights and blinker not working '82 pickup
  239. blow by
  240. 20r Timing with RV cam
  241. 1979 back from DEAD situation.
  242. 1974 front drum to disc brake
  243. 2 in shackle lift
  244. Checking rear diff wear?
  245. EACV Help
  246. Overheating after head gasket
  247. Alt relocate to passenger side
  248. Wierd Starting Issue, please help!!!
  249. Best 22R Rebuild Kit
  250. Exhaust Manifold Gaskets Extras????
