81 22r slow start when hot
I'm having a slow start issue when the truck is warmed up. Battery and alternator check out fine. The truck cranks perfect even when it's below freezing outside.
The issue arises when I cut the truck off and try to start it back within about 10 minutes. It barely turns over. The truck has not failed to crank as of yet.
Time for a starter rebuild or possible bad connection?
its good. i mean when the engine is warmed up at operating temperature. it acts like a heat soak issue as its only after ive driven it for a bit.
I was leaning towards a bad ground but i would think that it would do it when it was cold also. Another reason I would lean towards a bad ground is when the truck is idling, if i turn on the blower motor, it pulls the power down so bad it almost stall it out.
i dont know if this will helpp by my 68 ford does this and come to find out it is the starter getting to warm. does your starter have a heat shield on it if not try putting one on there
I'm also curious to hear how this pans out. I've had this issue before (with Ford trucks, never Toyotas - although anythings possible). I've wrapped the starter in that heat shield wrap, put in a heavy duty ground wire kit, new starter, full tune up, new battery, et cetera. It still does it. Runs great, BUT, like the original poster said: if it is warmed up, and you turn it off and come back in a few minutes, it has a heck of a time firing up.
If starter motor tries to turn but groans (struggles), AND you say battery is fine, possible problems are high resistance in battery-to starter solenoid contacts- to starter motor- to ground. Could be solenoid contact (see 4 Crawler's site).
Thermostat does not affect cranking
First-gen starting (cranking) system explained here.
Except that, I believe the 81 does not have a starter relay. Ignition switch contact closes, sends power to coil of starter solenoid. Solenoid actuates, contacts close and send power to starter motor. Also actuates a gear to engage starter and flywheel.
Good luck and Merry Christmas.
06-01-2021 01:51 PM
Avenged
07-09-2015 07:55 AM
