Pre 84 Trucks 1st gen pickups
Timing screwed up.
Old Oct 29, 2012 | 06:19 PM
natemoses13's Avatar
Timing screwed up.
Can anyone advise me on how to ensure my timing is correct?
I did a head gasket job on my 22r because water and oil were getting into cylinders 3 & 4. I put the engine at TDC before opening and made sure that neither the crankshaft nor the camshaft were rotated throughout the whole job. However, when I put everything back together and tried to start it, it will start but not run well at all. It barely runs and will not idle, sputtering and backfiring.
Should the top sprocket for the timing chain have the hole towards the top or bottom if the engine is at TDC on the compression stroke (piston 1 and 4 at the top)?
I think i messed up the timing chain somehow, but I would appreciate help on how it should look.
Old Oct 29, 2012 | 06:20 PM
BigBluePile's Avatar
Sounds like you stabbed the dizzy wrong
Old Oct 29, 2012 | 06:28 PM
Hmm, so if i were to guess, that means that I put the timing chain back on wrong.
I think I assumed that, but I am curious if anyone knows what it should look like? There is a mark on the camshaft, and a mark on the top timing chain sprocket. These should direct me to the correct position if anyone knows what those would be. Anyone who has done a timing chain or HG job should be able to help, please?
Old Oct 29, 2012 | 07:34 PM
Lol look for iamsuperbleeders motor build or 92toy for his build
Old Oct 29, 2012 | 08:17 PM
Boyoda's Avatar
May be a vacuum leak...I did a head gasket not that long ago, and that was the problem. Spent almost 2 hours messing with the dist. before I found the problem. (got distracted and put a ground wire between plenum and intake manifold.)
Boyoda's Avatar
Also, when you took the head off, you should have seen #1 was up.
Old Oct 30, 2012 | 03:47 AM
This is what it looked like.
Piston #1 and #4 were up.
Old Oct 30, 2012 | 03:48 AM
I have taken off all of the vacuum lines except the ones going to the distributor. I put a 32/36 weber in.
Old Oct 30, 2012 | 08:38 AM
Boyoda's Avatar
Did you re-use the intake gasket? Torque it down? Might be there...
Old Oct 30, 2012 | 09:02 AM
I used a new intake gasket.
Old Oct 30, 2012 | 08:58 PM
Little Elger's Avatar
Did you take the distributer out? May just be off a tooth, when reinserted.
Jun 1, 2021 01:51 PM
icentropy
Sep 16, 2020 02:47 PM
Yota.Jay
Jul 23, 2015 08:08 PM
msane99
Jul 11, 2015 08:08 PM
skoti89
Jul 6, 2015 07:45 PM
