Pre 84 Trucks 1st gen pickups
New radiator and HG?
Old Oct 22, 2012 | 04:11 AM
natemoses13's Avatar
Hey Guys,
I did some searching but found nothing like my situation, so maybe you can help me out a little.
I bought a 82 this past week and guy said it needed carb work (normal) but otherwise ran fine, and it did.
I kept needing to add coolant cause the radiator would be low, thought HG but it ran fine and no water in oil or oil in water.
I now hear air noise through the carb which when I release the radiator cap, the noise through the carb stops, meaning there is definitely a problem right?
What am I looking at? New HG only? Or new HG and radiator (the current radiator has gook all in it)?
I work on my other trucks and equipment all the time, but I am new to Yota's.
Can you offer any advice? Yes I spent a couple of hours searching.
Old Oct 22, 2012 | 06:33 PM
Bought the head gasket set today. How involved is this job? Any tips from those who have done it?
Old Oct 22, 2012 | 07:09 PM
waskillywabbit's Avatar
So have you actually tested it to confirm there is a HG issue? No way I'd tear it all down on guesswork.
:wabbit2:
Old Oct 22, 2012 | 07:20 PM
How would you go about testing it? I have air from the engine going into the coolant system....
Old Oct 22, 2012 | 10:10 PM
Chickenman's Avatar
Have you done a pressure test on the coolant system and a leak down test on all 4 cylinders?
Old Oct 23, 2012 | 03:51 AM
I will go ahead and get that done, but it seems fairly self explanatory..... Air pushed into radiator when engine turns, radiator spits water out.
Old Oct 23, 2012 | 03:44 PM
I removed the spark plugs and the plugs from cylinders 3 & 4 had gray gook on them. The gray must be from oil and water getting into there so I am certain its a HG. I am going to replace that, and I will wait on a radiator or anything else.
kawazx636
Oct 6, 2021 03:03 PM
ladybugRC
458
Aug 21, 2020 10:41 AM
mreagen
Oct 5, 2015 04:27 PM
scott90
Oct 4, 2015 09:21 AM
Matthew Perez
Sep 28, 2015 05:43 PM
