Pre 84 Trucks 1st gen pickups
22r 2.25 pipes!!???
Old 10-10-2012, 05:51 PM
cman1's Avatar
22r 2.25 pipes!!???
is there any proven benefit other than a nice tone to a 2.25 pipe and muffler out of the stock manifold on a 22r with no emissions?im trying to fix my leaky exaust from the end of the stock down pipe back. any suggestions would be appreciated?
Old 10-10-2012, 09:00 PM
caboussleman's Avatar
Only thing I could think of is that you might loose some back pressure if you go to big which in turn is lose of power.
Old 10-23-2012, 09:21 AM
KryptoRoxx's Avatar
It also depends on whether it has any performance parts on it. Once it's opened up with a weber/cam/etc the 2.25 should be what you are running imo. Most performance headers you can purchase come 2.25 or 2.5 if I am not mistaken.
Old 10-23-2012, 11:06 AM
RobotMoose's Avatar
FWIW any new OEM-style muffler is 2.25", and most exhaust shops will recommend moving up to 2.25.
I recognize the additional power from a header, but I consider exhaust work on a stock manifold to be by-and-large BS.
Alot of exhaust mods give the illusion of power because it makes the car sound louder.
Old 10-23-2012, 03:46 PM
donomite49's Avatar
i would run the bigger size exhaust, if your manifold cracks(which they do) you can buy a header and wake up the old engine.
i installed a header and 2.5" exhaust, cold air intake and had more power, low mid and top end, on my 22re, before i did my swap.
Old 10-23-2012, 04:08 PM
cman1's Avatar
well,heres my deal,i had/have a stock exaust front to back..last weekend i took the whole thing out, had a whole in my downpipe from rubbing on my leaf spring bolt,trimmed bolt ,welded a patch on the downpipe,had 6 leaks from the flexible pipe to tailpipe.proceeded to weld up every joint! took all the crappy clamps off. im gonna wait till spring and save for a header to tailpipe 2.25 exaust.dont wanna half arse it then add a header later! thanks for all the input guys!!!
Old 10-23-2012, 08:42 PM
RobotMoose's Avatar
That is a legit exhaust mod. You really have to go all the way to get good flow, otherwise you'll just end up with a tuner with a fart can!
kawazx636
10-06-2021 03:03 PM
buckz6319
08-05-2017 03:50 AM
Iceman4193
10-16-2015 10:50 AM
Thamuel_
Domestic Swaps
10-03-2015 11:15 AM
Toys4parts
09-26-2015 01:56 PM
Quick Reply: 22r 2.25 pipes!!???
