Pre 84 Trucks 1st gen pickups
T-Case supposed to spin while trans in N?
Old Nov 18, 2012 | 02:47 PM
Mr. Spooky's Avatar
Hello, just finished my rear main seal and rebuilt manual trans with new clutch. I moved the truck out of the garage and started it (No driveshafts installed) and while in N the flange on the T-case spin. I can grab it and it will stop and start up again when I let go but wondering if I screwed up the clutch and its not fully disengaging. The same with the front flange on the t-case, even while in 2hi it will spin and I can grab it and it will stop then start again when I let go.
Thanks
Mike
The flange does stop if the clutch is depressed. So I guess it is disengaging. Been working on it all day and am beat. I am guessing the spinning of the flange in N is just friction from all the internals of the trans. I hope.
Old Nov 19, 2012 | 03:36 PM
thefatkid's Avatar
Yes, due to the viscous qualities of your oil there is drag from the input shaft to main shaft through mutiple bearings.
Old Nov 19, 2012 | 04:47 PM
d_bomb's Avatar
yea, just the oils. If you've ever driven without a shiftboot, you can get a perfect view of the front driveshaft, and when it's cold out you can see it spin slowly while driving in 2wd with the hubs unlocked.
Old Nov 22, 2012 | 02:42 PM
Mr. Spooky's Avatar
Thank you all!
JHalcyonM
Sep 14, 2015 01:10 AM
an1mal_69
Sep 8, 2015 09:40 AM
zz_denis
Sep 6, 2015 03:43 PM
May-39
Sep 6, 2015 01:05 PM
moparbay
Sep 3, 2015 12:48 PM
