Pre 84 Trucks 1st gen pickups
Turning an 84-85 LWB frame into a 1979-83 frame
Old Jan 29, 2013 | 08:23 PM
gillesdetrail's Avatar
Hi, the frame is rotten out on my 81 SWB and I have started looking for another one, but they are very hard to come by around here and could end up costing 600-1000$ with shipping if I get a clean one from a rust-free location.
I found a clean 1985 LWB frame for 100$ about 3 hours drive from me, and I am wondering what would I get myself into if I wanted everything from my 1981 truck to fit. How much work would it be to get the correct dimensions, body mounts, etc and how much cutting/welding is required, would it be worth it to save the money and what would you do?
Thanks!
Old Jan 30, 2013 | 12:03 AM
wyoming9's Avatar
Red face
Depends if this is a long term project or if you need this up and running in a few days.
Never having to be in a position to do this job I can only guess that lots of things will be different.
Being you seem to be able to do the work it might be easier to use these good frame parts to replace the bad sections in yours.
Things like this are hard to call with out being up close and personal.
Finding another truck that year in good shape might be a real challenge and using yours as a parts truck.:wabbit2:
Old Jan 30, 2013 | 06:29 AM
MudHippy's Avatar
It can be done. But it's A LOT of work. And it will take you A LONG time to do. Because there's a (capitalized expletive deleted) load of cutting and welding involved. So, you had better be a damn good cutter and welder for one. For another, you'd better have nice flat concrete pad(preferably covered/indoors) to do this all on. You can't just "eyeball" welding a frame together. Which brings me to the next thing, measurements, measurements, measurements, and more measurements. If you want it to come out right, you'd better do it by the book. Good thing there's FSMs with all of those frame dimension specifications.
Oh, and one last thing, I'm speaking from experience.
BTW, don't count on a $100 junkyard frame to be perfectly dead-nuts straight and perfectly usable as-is. Meaning, you might be in for quite a bit of "unexpected" labor just fixing other things wrong with it(besides it being too long, and having most of it's parts welded on in the wrong places). Even if there's isn't a significant amount of rust damage.
Old Jan 30, 2013 | 06:55 AM
Thanks for the advice! I apreciate it!
The frame is aparently in good shape and he is getting rid of it, it's not from a junkyard. I have access to a welder and have a friend with good welding skills but we dont have much fabbing experience. With the money I save with the frame I was thinking about bringing it to a specialized shop and have them do the modifications. As for the body mounts, I'm thinking maybe I don't have to cut and weld them since I have to build a new floor for my cab and I can drill new holes on the floor for the existing body mounts.
So is there only one area of the frame I need to cut and shorten to get the proper wheel base or is there more than one place that will need modifying?.
Old Jan 30, 2013 | 06:57 AM
There were more bad parts on my frame than good parts so I aldready cut my frame in half to make room in the garage. And my deadline is 1st july since I have a wheeling trip planned.
Old Jan 30, 2013 | 07:01 AM
dropzone's Avatar
Fossilized
I hope you got measurements, lots of them before you cut up the stock frame...
Old Jan 30, 2013 | 07:08 AM
Well....no
When I cut it up I knew I wanted a 79-83 frame, I guess I made it that much harder for me huh...
Old Jan 30, 2013 | 07:21 AM
If only money wasn't an option....brand new frame!!! http://montreal.kijiji.ca/c-autos-et...AdIdZ446077406
Old Jan 30, 2013 | 07:37 AM
MudHippy's Avatar
Just one, AFAIK.
Not too much. If you have the 83 FSM.
https://www.yotatech.com/forums/f114...wnload-261385/
Old Jan 30, 2013 | 07:42 AM
Yes I have measurement pictures for both the 85 and 81 from the FSM, thanks.
I would need to remove 265mm or 10.43" of wheel base.
The 85 frame is 4.71" longer from the crossmember to the front, so it will probably need a new front drive shaft.
young buck
18
Aug 27, 2018 02:40 PM
Backcountry411
Jul 24, 2015 08:06 AM
yourrealdad
Jul 21, 2015 11:13 AM
hexrain
Jul 12, 2015 01:13 PM
