Pre 84 Trucks 1st gen pickups
front axle bogging it self down
Old Feb 20, 2013 | 07:42 PM
crazymudder's Avatar
how is it to rebuilld a front end on a 83 yota because i cant engauge my 4wd without boging itself. it just starts to draging the front tires and bounces when in 4wd
Old Feb 20, 2013 | 08:03 PM
BigBluePile's Avatar
Wrong gear ratio?
Old Feb 20, 2013 | 08:29 PM
runs-on-4's Avatar
or blown up diff...
theres a sticky on an solid axle rebuild
Old Feb 20, 2013 | 08:43 PM
The gears are right. It goes forward for a few then starts acting but in reverse it drives. I may just pull it all down grease until I get some money to the whole thing
Old Feb 20, 2013 | 09:02 PM
DeathCougar's Avatar
Old Feb 20, 2013 | 11:53 PM
dropzone's Avatar
Fossilized
you locking the hubs/4x4 on dry pavement?
the symptoms you describe sound like mismatched gears or your front diff set up was done by an idiot
Old Feb 21, 2013 | 03:54 AM
Yeah the guy I got it from said the owner be for him said it just need to be pulled down greased one good time
Old Feb 21, 2013 | 04:02 AM
dropzone's Avatar
Fossilized
huh?
the third needs to be pulled?
So how do you know the thirds match front and rear?
Sounds like the guy before the guy you got it from screwed the guy before you and your guy screwed you.
Thirds (differentials) use gear oil in the housings...the knuckles (birfields) use grease.
Old Feb 21, 2013 | 08:36 AM
enigmaT120's Avatar
There is a sticky on rebuilding a front axle, but it sounds like you might need more. Mostly diagnosis....
https://www.yotatech.com/forums/f114...ctures-223729/
Old Feb 21, 2013 | 01:35 PM
i may try to find a used complete axle or diff
Old Feb 21, 2013 | 11:09 PM
TheChewMaster's Avatar
Dude, I'm not sure you understanding what's going on here.
Buying a new axle? You are going to have to find out what ratio is in the rear to match in the front.
If it was me I would pull the third and check the the ratio and see it the ring gear or pinion are trashed. Start there and also you really shouldn't drive in 4wd on pavement, it can act funny.
Old Feb 21, 2013 | 11:25 PM
What exactly do you plan on greasing that will magically fix this issue?
Old Feb 22, 2013 | 04:08 AM
I really don't ever drive it on pavement unless I'm crawling around at my house or the holes around town. I plan on grease all the bearing and birfields but im going pull down the third and check everything to make sure its all good.
Old Feb 22, 2013 | 05:12 AM
bone collector's Avatar
ok here it is: the overwhelming suspect of your problem is mismatched gears in the rear and the front. It would seem that the rear gear ratio is 4.10 and the front is possibly 4.56 or 3.90. What this means is when you are driving in 4 wheel drive the front and rear are spinning at different speeds. So when you put it in 4wd the front will bind to a halt. The only way to check this is to pull the 3rd members from the front and the rear and to count the teeth on each. Count the ring teeth then divide by the pinion teeth. i.e. 43 ring teeth and 10 pinion = 4.30 gear ratio
Old Feb 23, 2013 | 04:48 PM
Thanks everyone I'm going to check that over the week hope that's it
Old Feb 23, 2013 | 05:09 PM
ThatGuy1295's Avatar
What do you mean "crazymudder"?
88sasturbotoy
Jan 30, 2026 01:57 PM
oldirtydirt
Feb 23, 2020 09:30 AM
jerusry
Oct 19, 2015 05:28 PM
deepmarsh
Aug 6, 2015 03:44 AM
Cabell
Jul 24, 2015 12:14 PM
