Pre 84 Trucks 1st gen pickups
Brake and clutch brackets
Old Dec 29, 2012 | 01:04 PM
Lons81's Avatar
I'm in the middle of my rebuild, with a question. I have the clutch and brake pedal brackets out and cleaned up for repaint. Is there any "heads up" I need to know, while they are on the bench. I will be upgrading the brake booster and master cylinder to the 1", when the time comes.
Old Jan 5, 2013 | 10:40 AM
Lons81's Avatar
Mods can delete this thread, since no info was provided. Thanks
Old Jan 5, 2013 | 11:13 AM
suncomb1's Avatar
When you add the 1" new master cylinder to your booster make sure you check / adjust the master cylinder / booster clearance noted in the factory service manual otherwise you will be pumping your brakes to build up enough pressure to stop. Also adjust your brake pedal rod to the proper FSM specification.
jasonty
41
Dec 23, 2018 01:00 PM
Sep 4, 2015 09:27 AM
shisha1999
Aug 14, 2015 01:33 AM
toyoterferdayz
Diesel Swaps
Jul 27, 2015 05:25 PM
whereAreMyPants
Jul 22, 2015 03:32 AM
