Pre 84 Trucks 1st gen pickups
Massive Oil Spray
Old Oct 16, 2012 | 02:27 PM
Bowdrie67's Avatar
Massive Oil Spray
Hello all, 81 YOTA P/U w/22R Engine. Daily driver with approx 30K since rebuild (all done before I bought it 2 years ago). Noticed oil in parking lot at work, checked oil and discovered everything under the hood is covered in oil. Have discovered lots of oil in the air filter housing as well. Added oil and limped home (6 miles) by the time I got home truck runs/sounds ok but oil pressure drops to nothing at idle. Not sure where to start to determine cause.
Thx in advance to all.
Old Oct 16, 2012 | 02:38 PM
brianh699's Avatar
Most likely the crankshaft seal on the front of the timing cover. It leaks onto the crank pulley and sprays everywhere. It can be changed with the cover on,but you half to remove crank pulley. Very common problem on 22r.
Old Oct 18, 2012 | 09:04 AM
snailwagon's Avatar
A crankshaft seal doesn't relate to oil in a filter housing. Pull the vent tube off the valve cover and throttle the engine and you'll see what's shooting out. An over pressurized crankcase can shoot oil throughout a bunch of seals, and can be caused by all kinds of things. Anywhere from a solid clogged cat, to broken rings on a piston.
chukarhunt
Dec 8, 2019 11:39 AM
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
Toyvana
Jul 29, 2015 10:47 PM
calderp
Jul 27, 2015 09:58 AM
Backcountry411
Jul 24, 2015 08:06 AM
