Pre 84 Trucks 1st gen pickups
cat/exhaust problem?
Old Oct 17, 2012 | 05:40 PM
rolltide81's Avatar
hey the 1980 4x4 20r my wife drives started rattleing like crazy so she got out and its sounded like a rock in a tin can comeing from the catylitic converter the she kept drivein and there was a huge backfire more than usual haha...and the the rattleing stopped and where the exhaust comes from the manifold was glowin red.now its louder than hell everythinsconnected.is it possiable for this to happen if your cat goes out?
Old Oct 17, 2012 | 06:51 PM
kawazx636's Avatar
This is an easy fix... Stop letting your wife drive your truck!
Old Oct 17, 2012 | 06:52 PM
82odyota's Avatar
I would think ur car took a dump cut it out or replace if u have to keep it see what happens im assuming u had very little flow so it got hot the backfire can get worse with exhaust restriction
Old Oct 17, 2012 | 07:13 PM
d-wood's Avatar
If you want to keep your cat converter, take it off and see how clogged it is. You can take some lacquer thinner and pour into it or you can soak it in some laquer thinner. Some people will pour it in there tank and drive around and see it if helps.
If you take the cat off, you dont want to break any bolts. You will have to probally go slow with the help of PB Blaster.
Old Oct 18, 2012 | 05:38 PM
rolltide81's Avatar
took it off and that gunshot of a backfire was it blowin the rest of what was inside out its was completly bare inside ..so screw it bolted it back on and added a muffler and supports i guyess problem solved
Old Oct 18, 2012 | 06:46 PM
cman1's Avatar
yep! i agree..
SubiKing
Aug 21, 2021 03:57 AM
theking11863
Mar 19, 2016 09:36 PM
Logz808
Jul 26, 2015 07:09 AM
Jonny246
Jul 24, 2015 12:37 PM
kyletbert
Jul 17, 2015 11:39 AM
