Pre 84 Trucks 1st gen pickups
1982 22r carb issues..
Old Sep 21, 2012 | 04:59 PM
SVOman8284's Avatar
Bought my first 4x4 project a month ago. 1982 4x4 4speed, it would idle for about 2 minutes before it would die so i thought it had really bad fuel gummed so i decided to rebuild the carb during the time i was replacing the timing chain. now it wont harldy start at all ( i have to pour fuel in the carb )nand i have to floor it to start. it has new fuel pump rebuilt carb and new fuel filter. when it does run i have to keep it revving pretty high prob above 3 grand and if you let off the gas it just dies and wont restart. the ticrod from the chain is gone now but it wont start or idle. no vac leaks dist is in properly. Any ideas guys?? thanks !
-J.W
Old Sep 21, 2012 | 05:36 PM
slacker's Avatar
are you sure you have timing set correctly ?
Old Sep 22, 2012 | 03:07 PM
SVOman8284's Avatar
timing is set correctly, 0 degrees ( on the pulley ) on #1 cyl..
i think thats right isnt it ?
Old Sep 24, 2012 | 05:58 PM
SVOman8284's Avatar
it was the fuel mostly, it was seriously bad and contaminated, timing was set properly, and i just have to fix a oil leak in the oil pan, and i should be good to go once i clean the tank and adjust the carb.. ahh the ol slippery slope !!!
Old Sep 24, 2012 | 07:51 PM
cman1's Avatar
check ALL YOUR VACUUM LINES!
Old Sep 25, 2012 | 05:01 AM
RobotMoose's Avatar
Some oil leaks can look like the pan gasket, but sometimes are the oil seal on the timing cover behind the crank pulley.
Had that happen a few times, oil would blow out from that dead seal, and get forced along the track of the oil pan.
I thought I kept botching my expensive FIPG both times.
buckz6319
Aug 5, 2017 03:50 AM
Iceman4193
Oct 16, 2015 10:50 AM
Thamuel_
Domestic Swaps
Oct 3, 2015 11:15 AM
Toys4parts
Sep 26, 2015 01:56 PM
taraf
Sep 25, 2015 02:57 PM
