Pre 84 Trucks 1st gen pickups
1984 pu auto trans weber conversion
Old Dec 22, 2012 | 01:47 PM
nobdays's Avatar
Hi, Im new here & also to my truck its a 84 pu 2wd auto built sept 83 with low miles its hard starting when cold & uses too much fuel I think, thinking of weber 32/36 kit but not sure if the install is simple enough with the auto trans anybody done one pictures would help
Old Dec 22, 2012 | 08:58 PM
JonnyBoy's Avatar
Is there a kick down cable or rod or something to make the trans downshift when you have to put your foot in it? If not, it should be pretty much the same install as any manual pickup.
Old Dec 23, 2012 | 12:01 PM
nobdays's Avatar
yes theres a kickdown cable
Old Dec 23, 2012 | 03:02 PM
JonnyBoy's Avatar
It might take a bit of welding or fabrication of some sort to hook the cable to the throttle linkage, but I'm not sure what, exactly. Can you post a picture of the kickdown cable and stock throttle linkage?
kazuya2416
Apr 5, 2024 02:17 AM
akamon808
3.4 Swaps
Dec 16, 2015 08:45 PM
priest16
15
Aug 6, 2015 07:43 AM
D.B.T. 87 4x4
Jul 20, 2015 04:51 PM
andrewtexas123
Jul 14, 2015 04:29 AM
