Pre 84 Trucks 1st gen pickups
Ring gap orientation and the 83 FSM
Old Feb 14, 2013 | 06:56 PM
thetundrawolf's Avatar
I don't have my computer handy, or I'd show you what the picture of the diagram for the piston ring gaps.
It looks like some sort of strange religious symbol with a bunch of degrees thrown in to make it impossibly confusing.
I have an 82 2.4L 4 cyl, and I am going to be putting the motor together hopefully tomorrow. I *need* to know just what they mean by the diagram.
Please, can someone help me?
Old Feb 14, 2013 | 08:32 PM
kawazx636's Avatar
Are you talking about this picture:
Or maybe this picture:
If so it refers to the piston gap alignment. You want all of your ring gaps to be roughly 90* off set.
Old Feb 14, 2013 | 09:40 PM
Do those apply to the 82 2.4 l pickup? No, the pic I am talking about is three or four x's drawn in a circle with degrees between some of the lines. it is insanely confusing. But those pictures are very simple and easy to understand.
Old Feb 14, 2013 | 11:45 PM
wyoming9's Avatar
Red face
The main thing is just don`t have the ring gaps close to each other .
Just think if all the ring gaps were lined up your rings would never seal leaving the engine unable to build compression.
Old Feb 15, 2013 | 05:49 AM
MudHippy's Avatar
Same general idea. Just 60°/120° offset from each other and 30° offset from center(top to bottom). Instead of 90°/90° offset from each other and 45° offset from center(top to bottom).
Old Feb 15, 2013 | 02:49 PM
Yes, that's the picture I was talking about.
Now that I look at it, the two twenty degree marks threw me off.
What are those spikes sticking out from the piston itself? Is that the ideal orientation?
Old Feb 15, 2013 | 05:07 PM
MudHippy's Avatar
They are imaginary lines representing the gap widths of the 4 individual rings, and where they should be oriented in relation to the piston face.
Like those in the pic below(just much skinnier in the pic above).
Yes. Though, for whatever reason, they decided that it wasn't ideal on later versions of the same engine.
alexcarey
Oct 14, 2015 06:05 PM
dzldust
7
Oct 6, 2015 05:39 AM
hiluxinargentina
Sep 30, 2015 05:51 PM
charlie_fong
Sep 27, 2015 10:06 PM
Odin
Sep 26, 2015 06:56 PM
