Pre 84 Trucks 1st gen pickups
79 4x4 pickup 20r carb problems
Old Feb 25, 2013 | 03:06 PM
79jyota's Avatar
I'll try to make a long story short. Bought a 79 4x4 for an extra camp truck so dont want to get too involved in this project. It wasnt running when i bought it. Gas tank is rusted out and carb is leaking from every place it could possibly leak and is beyond rebuild. I put a small gas tank in bed and an electric fuel pump for now until i can fix stock tank. I cleaned all the plugs and distributer cap and got it running with a lil carb cleaner and starter fluid pouring gas straight in carb. Now for the questions. If i get a weber carb, do i need a return for the fuel line? What psi should fuel be for weber carb? and do i need a regulator to keep psi down if no return? Any help would be appreciated!!
Old Feb 25, 2013 | 03:13 PM
79jyota's Avatar
also, can i just plug up the extra lines that is on stock carb?
Old Feb 25, 2013 | 03:32 PM
Rollz79's Avatar
I don't have a return line on my Weber. Some people say having a return line helps. I run my Weber at 2.5 4 psi depending on where I am at. I would highly suggest a regulator if you plan to use the elec fuel pump. I run a holley style reg.
rondogracing
25
Dec 11, 2015 07:26 AM
bigblue82
10
Jul 6, 2015 08:27 AM
kazuya2416
Jun 27, 2015 12:24 PM
ItsAtoyotaLIFE
Jun 21, 2015 11:45 AM
paxanders
Jun 21, 2015 06:29 AM
