charge light come on for overcharging?
I just swapped over a gauge cluster that has a tach on it and the charge light was burnt out on the original one, so now with the new one the charge light stays on. I checked the volts and at idle its putting out a little over 17 at the bat. Will the charge lamp light up for overcharging? Tried taping the relay but I did nothing. Looks like a new voltage regulator is needed. Also the tach does not work but I am still troubleshooting that one.
Thanks
Mike
Thanks
Mike
Thanks for the confirmation.
Still no luck on the tach. I dont know if it worked to begin with, but I used up all my ideas so it looks like I need to find another one. If anyone has one they way to sell, I will take it. For a 1980, with the tach in the center.
Also is there a certain brand voltage regulator I should go with, one that you have had better luck with it lasting?
ashersullivan88yota
Jan 18, 2022 05:37 PM
FS[PacNorWest]: Toyota Inclinometer/Altimeter
AkitaDog
Sep 1, 2015 08:05 AM
mr_manny
Jul 31, 2015 10:39 AM
PopsDad1
Jul 30, 2015 02:21 PM
Odin
Jul 15, 2015 09:28 PM
It will to high or to low will set it off
