Pre 84 Trucks 1st gen pickups
Fuel Pump Check valve?
Old Sep 22, 2012 | 06:40 PM
d-wood's Avatar
I have a 1979 2wd 20r with a in tank fuel pump. Why does it have a check valve between the pump and the line? Can I bypass it? The new one I got from autozone is an airtex, which doesnt include the check valve.
I also had to cut my negative and positive wires because it wasnt a direct plug in. Also the strainer set up was alot different. Just FYI in case you got any advice on these.
Old Sep 22, 2012 | 07:35 PM
Mdumaw's Avatar
You have a check valve to help keep the fuel and pressure in the lines. Anti drainback valve I believe.
Old Sep 23, 2012 | 04:43 AM
d-wood's Avatar
Thanks, that has to be what it is. I didn't think of that.
smthwsn357
May 1, 2024 07:28 AM
Charecter1
Nov 6, 2023 10:08 AM
sandyota
Feb 4, 2021 11:16 AM
Sep 4, 2015 09:27 AM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
