Pre 84 Trucks 1st gen pickups
Is the hood, front bumper & seats interchangeable between 82 & 84 Toy pickup trucks?
Old Jan 12, 2013 | 03:08 PM
magentawave's Avatar
Does anyone know if the hood, front bumper, and seats are interchangeable between a 1982 Toyota pickup truck and a 1984 Toyota pickup truck?
Thanks
Old Jan 12, 2013 | 03:36 PM
DirtyHarry460's Avatar
hood.no. bumper.i dont think so but possible. seats. depends on how much work you want to do but i have no personal experience with that. probly pretty close match.
Old Jan 12, 2013 | 09:15 PM
Darn, bummer that the hood doesn't match cuz the one I want to replace has a few big nasty rust holes in it.
Old Jan 12, 2013 | 09:20 PM
dropzone's Avatar
Fossilized
1st gen was 79-83, rounded style body.
2nd gen truck 84-88 (4runner 84-89) are square'ish
Old Jan 13, 2013 | 04:16 PM
slacker's Avatar
none of it is "swapable"
Old Jan 15, 2013 | 12:18 PM
Not even the seats?
Old Jan 15, 2013 | 01:06 PM
dropzone's Avatar
Fossilized
Originally Posted by magentawave
Not even the seats?
not direct bolt in, but you can make the seats work.
If you aren't doing a bench seat swap I would not use the stock '84 seats I would do a set of early 90's acura integra seats..I love my Prelude seats...way more comfy than factory toyota seats IMO...well my '05 Taco seats were nice
Old Jan 15, 2013 | 01:07 PM
donomite49's Avatar
you can get more comfortable seats, a newer yota or something else. my 88 seats are the most comfortable imo.
i put mid 80's z28 seats in my 79 with stock yota brackets.
slacker can hook you up with a glass hood if you can't find a used one. i like hannemann glass as well.
Old Jan 15, 2013 | 01:25 PM
Sorry I didn't mention this before but these are buckets seats for both vehicles.
Will early 90's Acura seats fit in an 82 Toyota truck without modification?
Regarding the glass hood... Is "slacker" the username for someone on this forum?
Thanks
Old Jan 15, 2013 | 01:30 PM
dropzone's Avatar
Fossilized
not even a 2nd gen (and above) seat will be a direct bolt in mod.
Early 90's Acura Integra and Honda Civic seats work great in a 1st Gen truck.
These things are great, there is a second hole about 1.25" over from the stock front outside mounting hole that lined up just about right, enlarged it just a hair and was able to use the inside front stock mount:
just had to cut off about the lower .25" or so of the stock bracket to allow it to sit flat on the floor.
I think that being able to use the stock front holes makes the install much more stable and install went very fast...
outside rear mount came up with something similar to WSUWeston's brackets:
the inside rear mount just needs a hole drilled in the floor
the search is your friend
Old Jan 15, 2013 | 01:38 PM
donomite49's Avatar
slacker wrote post #5 above, there is a link in his sig.
here is a link to hannemann http://www.hannemannfiberglass.com/c...457567&page=17
Old Jan 15, 2013 | 01:46 PM
Thank you to both of you.
Did you make the rear seat bracket yourself or did you buy it off-the-shelf?
Old Jan 15, 2013 | 01:54 PM
dropzone's Avatar
Fossilized
bought some strip steel at lowes or home depot. measured, drilled it and bent it in a vice with a BFH..
Old Jan 15, 2013 | 06:41 PM
Do you remember how thick that steel was? 1/8" seems too flimsy. 3/16" thick maybe?
Old Jan 15, 2013 | 07:35 PM
dropzone's Avatar
Fossilized
It was probably 3/16" but if I was to do it again I would go 1/4"
Old Feb 4, 2013 | 03:09 PM
I finally got the two motorhomes parked in the same place and found out that the one that says its an 84 on the paperwork is actually an 83 which means the body parts are compatible with my 82. This is awesome because I was able to swap the hoods, front bumpers, side mirrors (and probably the seats next). I'm also swapping the rear axles between them this week too. Bottom line: This super cheapo "84" I scored will net me about $1400 in free parts by the time I'm done with it.
matrad
Aug 26, 2024 08:21 AM
gtpman98
9
Feb 14, 2003 06:21 PM
scotts93
Jun 26, 2002 01:32 PM
