2 in shackle lift
2 in shackle lift
I have a 1980 Toyota and I think it has a stock lift with 30 x9.5 and I was wondering with the front drive line, if I install 2 in longer shackles to the front do I have to extend the front drive line because of the angle difference?
shims can only correct up to a certain point before it impacts the angle of the knuckle balls
spot on info on shackle length
2" lift shackle will point pinion "down" some = crummy angle on your u-joints and possible align issues. Add a shim to bring the pinion back to "level" and you should be good to go. Ran with that setup for quite a few years and had no driveline issues. I would recomend a drop drag link to go with it or your steering would be spooky.
OME Med. duty front replacement
I am new to yotas. I am replaacing the front leaf springs (med. duty) on my 83 4x4 long bed SR5
-I want a softer ride for my daily drive and to and want to know if i should get soft duty shocks or mediam duty???
-what do people do for lengthening the torsion bar long bolt to the axel?? what I have dose not look right to me see pic (one side is still loose)
-I am pertty sure there is no left or right medium duty leaf springs??? one spring had a "0" and the other spring had a "1" painted on the leaf spring see pic
-is it necessary to do the rear as well? I so far I have only ordered the front setup. old springs were original and had a negitive arch.
1uzRunner
63
Nov 10, 2018 03:58 PM
