- Looking at an 83'
- Blonde moment?
- cant find a headlight door
- Engine trouble help asked for.
- can I use a front brush guard and a rear smitty built bumper from a 85 on an '83?
- The woes of wiring.....
- ignition module
- 1982 carb question
- sipeing tires?
- Cylinder Heads?
- swapping the 22r carb onto the 20r
- quick body mount question
- new truck just some Q's
- bolt extraction fun
- Why does my truck run like crap!!?!??!?!
- 20r head to 22r block swap carb questions
- Take a look at this!!!
- 1980 Pickup
- Oil & Volt Gauge Hook-up
- How rare are Trekkers? I found one for $500...
- 5.0L vs 4.3L
- Weber snokerl possible?
- add a leafs??
- Mule of the month for wiring....
- Selling my Ford for another toyota!!!!! Opinions???
- what is it??
- YJ leafs Qs
- 86 cab on 79 frame
- 1980 EGR valve
- any ADVICE FOR HOOKING UP SUBS IN A REG CAB?
- 1980 bed
- am i in more trouble than i think
- 80 Toyota Emissions Delete
- loosing coolant
- Running hot?
- rears up front
- 22r Hybrid Heads
- Torque Specs For 1983 22r Manifold Studs + Nuts
- idles but when starts to warm wont idle
- few Q's about for my 81 4x4
- New '83 w/ pics
- 20R/22R trans
- 22r help
- ebay finds
- power steering
- 82 4x4 + 31 inch Hokian vatiiva m/t = PICS.
- 82 cab on 79 chassis
- 32" tires will they fit?
- Seat cover for 1st gen????????
- light is blinking
- how should i fix frame
- Front grill
- bed length
- engine id questions
- My "truck won't start" thread
- light switch......
- grinding t-case
- Wheel spacers or offset wheels
- the 22R tribute vid thread.
- My new (free!!) 83
- Need bumper bracket detail 83!!
- Does my truck look lifted?
- weber vs aisin
- trouble with idle and warm start up
- roof drip rail pic ...
- My new 1st gen 4x4 with PICS!!!
- vacuum advance? need it or no
- flywheel fit
- New (to me) 81 setup questions??
- back on road after 9+ yrs but wont idle
- Front bumper removal
- pre 83 efi swap
- OME leaf springs
- Toyota Wolverine Featured 1978
- 85 pickup chassis on a 82 pickup
- Header install and smog removal questions.
- Second battery some questions, input
- Ring gear
- 81 carb selection??
- A few 1st gen questions please!
- Hilux diesel video
- my 20R to 22RE better late than never swap
- T-cases?
- 1980 Sr5 20 R Issues !!!!!????
- I need some ideas
- '83 Pickup questions: steering, exhaust studs, parts source
- weight?
- grey smoke when shifting... carb??
- what engine is good?
- gas leaking from gas cap
- Taking build suggestions.
- lift problems
- Holley 350 CFM Bolt up??????/
- New guy, new(old) truck.
- Toggle switch and push button start swap, need help!!!
- Need some driveshaft help!!!!!!!!!!!!!!
- tire size selection how do you?
- 1978 4x4 pickup
- 22r engine performance
- my 81
- Any interchangeable T-case gears?
- Pinion flange nut
- High Idle Problem After Carb Rebuild
- 22r problems
- Brake question
- door locks
- new 81 4x4 (new to me)
- Front axle Q?
- 1st gen topper
- 22R starting problem fixed!
- Clutch- a testament to doing it right...
- 20-r weber help
- new guy that just picked up a '83
- Gas smell
- Charge light and Brake light on after Alt and Reg Swap
- Longbed Shell/ Cap- Anyone know where to find one?
- couple of Questions. need advice.
- oem decals
- rev limiter?
- 1982/83 toyota pickup 4x4
- Idle/timeing ..
- Tail gate question
- 20R running hot a highway speeds
- tire date codes
- Need help with potential Charging Problems
- 1981 22r vacuum hose spagetti
- 20R Temp sensor
- lights/lenses?
- Ready to buy
- Charge Light
- electrical fire
- 83 tOY tRANS
- exhaust gasket seal problem
- Quick Questions-
- Question about tailgates
- Brake issue
- 1983 Toyota 4X4 build down
- Fuel sending unit and tank sensor?
- oil passages
- 79 Toyota pickup- lift spring ideas.
- concerns with front locker/axle strength
- Clutch issue remaining...
- shock length
- vibration from 15-20 mph
- 1st Gen TRUCK door locks and ignition set Matched On ebay
- Will An 86 Steering Stabilizer Fit An 84?
- Bad starting+lights on dash
- Sticky Clutch In the Cold
- 2nd gen bed on 1st gen
- 79 toy axles
- Wobbly speedometer needle
- Help with front end noise..
- leaf swap
- 4 Door 1st Gen
- Paint job ideas
- 82 Dash?
- 1st gen high steer
- 1983 & 1984 4WD Axle/driveline compatibility.
- Did any first gen have a gas light?
- oil pan
- smother ride
- bleeding LSPV
- Vibration culprits
- oil filter goes pop
- Roll bar question
- 1st gen transfer cases
- New suspension lift needed ?
- Trans will not go into 5th gear
- Transmission Questions
- Rain Tray Removal?
- I hate smelling gear oil
- Axle questions
- gone
- dang it!
- sloppy shifter
- 3/4 ton?
- 1977: Best place online for OEM parts?
- Anybody got an FSM?
- 20r won't cold start...
- How to tell what year 20r I have?
- Propane Hose
- toy mechanic's in Oregon
- cracked spring hanger
- 1978 Wolverine!
- 20r head removal
- front axle seals
- Improve your Brake Diaphram booster
- Fuel Pump issue
- Brakes question..
- oh wait, it's really intermittent
- How much is it worth?
- leaf springs
- 81 tranny issue
- Best Birfield replacements?
- leaf spring questions
- Windshield prices?
- Suspension or lockers
- Immediate Help Needed
- trailer light wiring
- Bed dimensions??
- squeal/squeek
- Wiring Diagrams for 79 2wd
- 20r to 22r swap help
- Lund Viser
- O rings?
- 1981 Toyota Monster Truck Project for Sale
- frankengrille
- engine install
- 1981 accident question
- 71 Hilux Trans Question
- transmission lengths
- rust! doh!
- My first yota and some weber carb swap questions
- 1979 short bed
- SR5 window glass.....
- Possible motor swap
- 1980 4x4 One Owner 57K Orig Miles (supposedly)
- machine shop info zinc and oill filters
- '81 vs '84~'85 drive train
- Front Hubs, How Hot?
- engine swap
- New Issue 85 Turbo Gas SR5 PU 2X2
- Hello All
- Ideas for a dash on my '82
- 83 4x4 tie rod need a new one?
- 83 Toyota crawler
- '81 Overheating problems
- need help with smoog stuff
- V6 Radiator 84-88...will it fit?
- AC in 1st generation.....
- wiper linkages
- I need sound!
- carb mods for steep hills?
- my pre-runner pickup
- Aussie or lockrite
- 82 toyta EFI
- Its the alternator right?
- 4x4 conversion for 82 p/u
- power
- Coolant system bypass? Little help..
- Coil Wire Poping off distributor cap
- carb ?
- Remote Controll 1983 Toyota 4X4
- Lift Kit
- repairing rust
- New Paint!!!
- Resto parts
- 1983 FSM Cheap!
- Got me a new 3/4
- Anyone have a 79-83 steering column cover
